Included in: Grammarly Pro, Plus, Business, and Enterprise plans
Managed by: All members or specific roles selected by admin
Knowledge Share helps your team members decode terms, such as acronyms or internal project names, by providing tooltip-like explanations—a definition of the term, key contacts, and links to relevant documents.
How to add terms to Knowledge Share
You can add the terms that you’d like to define in two ways:
  1. By going to the Knowledge Share page, clicking Add term, and selecting Add individual term:Add
  2. By opening the Knowledge Share page, clicking Add term, and choosing Import list. You will see the prompt to download a template, which you can fill in with the list of terms. Once that’s done, click Next in the same window and upload the file.
Additionally, you can benefit from our pre-set term lists by clicking Add term and selecting Add pre-set terms.
Once the terms have been added, Grammarly will highlight them for you and your team members. Hover over a highlighted term to surface its description, relevant documents, and key contacts:
Add
If you’re an individual Pro subscriber, you can make your subscription work for your entire team. By expanding it to a team plan, you can share advanced features with colleagues, improve productivity, and reduce repetitive writing. You can add more seats on the Members page.
Where does Knowledge Share work?
Knowledge Share is currently available in Google Docs, Gmail, Confluence, and Jira via Grammarly for Chrome, in Microsoft Word and Outlook via Grammarly for Windows, and Slack via Grammarly for Mac.
In Google Docs, Knowledge Share definitions will be displayed in documents that are not owned by you. In Gmail, term definitions will appear in emails that you have received or sent, but not in new emails you compose.
In Microsoft Word for Windows, you will see Knowledge Share highlights while writing, reading your documents in Read Mode, and viewing read-only documents.
In Microsoft Outlook, Knowledge Share definitions will be shown for incoming emails.
In Confluence and Jira, Knowledge Share definitions will appear for published text.
How to edit or delete Knowledge Share terms
To edit or delete a term, go to the Knowledge Share page and click on the term you’d like to modify. In the window that opens next, edit the term details and click Save to apply the changes, or click Delete term if you’d like to delete the term:
Edit
You can also start editing a term from its definition card that appears on hover.
Additionally, you can delete a term by locating it on the Knowledge Share page and clicking the three dots icon next to the term.
Note: When creating terms, you can add aliases (alternative names) for each term.
If you are the admin of your team’s subscription, you can select which roles allow your team members to create, edit, and delete Knowledge Share terms.
To do that, go to the Knowledge Share page, click on the three dots icon in the upper-right corner of the page, and select Settings.
Note: By default, the option to add, edit, delete, or export Knowledge Share terms is available to admins, account managers, group managers, users, and members with designated custom roles. The option to assign group manager permissions and create custom roles is available only to Grammarly Enterprise customers.
How to export Knowledge Share terms
You can export the terms in bulk by going to the Knowledge Share page and clicking Export in the upper-right corner:
How to turn Knowledge Share on or off
You can activate or deactivate Knowledge Share for your organization in the corresponding section of the Feature access page.
If you deactivate Knowledge Share, you and your team members will no longer see definitions of the terms added on the Knowledge Share page.
To stop receiving suggestions to create new Knowledge Share terms, go to Your preferences page and turn off Intelligent Knowledge Share term creation. This setting is controlled by each member independently.
