Reader Reactions user guide
The Reader Reactions agent is like a trusted teammate you bounce ideas off of before hitting send. Once you identify your target reader—such as your manager or client—this agent simulates how they might interpret your message. It predicts key takeaways, open questions, and potential confusion based on their predefined role and the substance of your writing, then offers revisions so you can refine your work with accuracy and confidence before sharing.
Availability
The Reader Reactions agent is available for Pro and Plus subscribers in docs and Superhuman Go. Users of Grammarly Free have access to a limited number of suggestions each day.
For Grammarly Enterprise, Grammarly Business, and Grammarly for Education users, the Reader Reactions agent is accessible in docs. When docs is enabled, agents are on by default. Admins can adjust agent access for team members on the Agent access page.
How to use
To have the Reader Reactions agent check your text, click the Reader Reactions agent icon on the right-hand side panel with your agents:
The agent will scan your text and automatically infer the target audience based on the content and style of the writing. However, you can always click the “audience” button on the top-right of the screen to choose a different audience that better fits the writing task:
Once you’ve selected an audience, the Reader Reactions agent will scan the full document and provide a brief summary of the writing quality and what is likely to resonate with the reader. Review the feedback on what this audience type will remember from your text and consider the potential questions the selected group might ask based on the details presented in your text.
Hover over the bars on the left side of your text to see suggested actions for customizing your message for the target audience. Clicking the Show example button will provide a suggestion on how to improve your text. You can either insert the suggested example or dismiss it and create your own version, adjusting it based on the Reader Reactions agent's suggestions:
If you’re on the Free plan, consider upgrading to Pro to increase your productivity and boost your communication. Visit www.grammarly.com/plans to see what advanced features you can access and choose the plan that suits you the most.
