Humanizer user guide
The Humanizer agent is like your editor with emotional intelligence, fine-tuning your AI-generated writing to sound more natural, sincere, and distinctly human. It helps you eliminate robotic phrasing, add warmth or nuance, and ensure your voice feels authentic to your audience, whether you’re writing an email, a proposal, or a blog post.
Availability
The Humanizer agent is available in Superhuman Go and in our AI writing surface, docs, for Grammarly Pro, Grammarly Plus, and Grammarly Free subscribers.
For Grammarly Enterprise, Grammarly Business, and Grammarly for Education users, the Humanizer agent is accessible only in docs. Admins can manage their team members’ access to agents on the Agent access page.
How to use
To change the voice of your text, click the Humanizer agent icon on the agents tab on the right side:
You can add your own voice or choose one of the available options:
Click Create a voice, give it a name, and add your writing sample of 200 words or more as a style reference.
The Humanizer tab shows detailed suggestions for improving your text. Hover over the bars on the left side of your text to see actionable feedback prompts that guide you on how to update the text in line with your preference:
Note: Your custom voice profiles are shared between both the Humanizer and Paraphraser agents that are available in both Superhuman Go and docs. This means once you create a voice profile in one place, it’ll automatically be available in the other.
