Before installing Grammarly for Safari on iOS, make sure to update your operating system to iOS 15. At this time, older versions of iOS are not supported by this product offering.
To begin the installation, follow these steps:
  1. Open Settings and go to Safari.
  2. Tap Extensions and then choose More Extensions.
  3. Search for Grammarly in the App Store and install the extension. Keep in mind that this action will also install the Grammarly Keyboard for iOS on your device.
  4. Then, return to the Extensions menu in your device’s Settings and switch on Grammarly.
If you previously installed Grammarly for iPhone on your device, follow these steps instead:
  2. Tap Extensions and switch on Grammarly.
For more information about this product offering, check out this guide: How does Grammarly for Safari on iOS work?
If you’d like to install the Grammarly browser extension on your desktop computer or laptop, see this article: How to install the Grammarly browser extension
