Leading the evolution of digital writing, Grammarly introduces its generative AI assistance to the Grammarly Keyboard for iPhone and iPad users, a feature that perfectly aligns with today’s dynamic writing demands. Whether you’re drafting an email that needs a personal touch, composing a captivating social media post, or crafting a formal document, Grammarly’s AI writing partner stands ready to elevate your writing.
How it works
The process of utilizing the Grammarly Keyboard’s AI writing assistance on your iPhone or iPad is intuitive and user-friendly:
Start by selecting the text you wish to improve.
Multiple tone options will appear at the bottom of the panel. Tap the one you want, depending on the nature of your communication:
If you prefer not to replace the highlighted text but want to use the revised content elsewhere, tap Copy Text.
Note: Each Grammarly user has a set number of prompts they can use in a given day. Each time you type something into the prompt field or select one of the suggested prompts generated by Grammarly, this counts toward your usage limit.
If you’re on the Free plan, consider upgrading to Pro to increase your productivity and boost your communication. Visit www.grammarly.com/plans to see which advanced features you can access and choose the plan that suits you the most.
