With Grammarly’s personal dictionary feature, you can make sure that unique words in your lexicon won’t be flagged as misspelled.
If you’d like to stop flagging a particular spelling as incorrect, you can add the word to your personal dictionary by clicking Add to dictionary on the suggestion card:
A gif shows a cursor hovering over a book icon on a suggestion card
To manage your personal dictionary, sign in to your account, go to Account → Writing, and select Your dictionary:
To add a word, enter it in the corresponding field in the Your dictionary menu and click Assign.
To remove a word from your personal dictionary, hover over the word that you want to remove and click on the trash bin can icon that will appear next to it:
Keep in mind that only words containing English language letters, hyphens, and some other symbols can be added to your personal dictionary. The maximum word length is 100 symbols.
Note: The words with special symbols such as !, ?, +, $, &, or / and several words separated by space cannot be added to your personal dictionary.
Once you add a particular word to your personal dictionary, it will not be flagged in other Grammarly product offerings.
Note: Admins of team plans can activate or deactivate personal dictionary for all members of their plan, or for select groups, on the Feature access page. If you are a member of a team plan and you cannot access the Your dictionary page, it means this option has been turned off by an admin.
If you’re on the Free plan, you can upgrade to one of the paid tiers at www.grammarly.com/plans to access advanced writing features and boost your productivity.
