To uninstall Grammarly for Android, please follow the instructions below:
  1. Touch and hold Grammarly’s companion app.
  2. Tap Uninstall.
  3. Tap OK to confirm.
Alternatively, follow these steps:
  1. Go to Settings on your mobile device.
  2. Scroll down to the Apps or Applications Manager menu.
  3. Find Grammarly in the list of apps and tap Uninstall.
We’d be happy to assist you with any issues you may encounter with our product offerings! If you experience a technical problem, check out this section of our Help Center: Resolve Issues.
