Introducing paragraph-level rewrites
Paragraph-level rewrites reduce the time you spend on your text by quickly rewriting entire paragraphs or selected sections of text. You can apply multiple suggestions with a single click. For the selected text, you can also choose to improve, rephrase, translate, shorten, or make it friendly or formal.
The paragraph-level rewrites are available in Grammarly for Windows and Mac, Superhuman Go for Windows and Mac, Grammarly and Superhuman Go browser extensions for Google Chrome and Microsoft Edge, and in our AI writing surface.
If you are using Grammarly or Superhuman Go for Windows and Mac, or the Grammarly browser extension, paragraph-level rewrites will appear as a blue sideline once you select your text, or a gray sideline if you hover over a paragraph.
Note: The gray sidebar may not appear in some text fields.
If you like the suggested change, click Accept or Insert:
If you are using the Superhuman Go browser extension, you will see a “hero” icon once you select the text. Click the checkmark icon to accept changes.
Multilingual paragraph-level rewrites
Paragraph-level rewrites are available in six additional languages: Spanish, German, Ukrainian, French, Italian, and Portuguese.
To use multilingual rewrites, select the text written in any of these languages. You will see the same options to Improve, Rephrase, or enter your own prompt that are available for English texts:
Manage this feature
If you’d like to turn off this feature in Grammarly or Superhuman Go for Windows and Mac, or in the Grammarly browser extension, go to the Feature access page and turn off Paragraph-level rewrites.
To turn off this feature in the Superhuman Go browser extension, follow these steps:
  1. Click the Superhuman Go icon in your browser’s toolbar.
  2. Turn off Show for selected text while writing:
If your Grammarly license was purchased through our Sales team, your admin will need to enable paragraph-level rewrites to grant you access to this feature. Here is how they can do that: Introducing the feature access panel
If you’re on the Free plan, you can upgrade to one of the paid tiers at www.grammarly.com/plans to access advanced writing features and boost your productivity.
