Fix sign-in problems when your login details are correct
Note: Grammarly is now part of Superhuman, a suite of AI tools that includes Go, Grammarly, Coda, and Mail. If you are a Superhuman user, please check out this article: Problems signing in to Superhuman
If you can’t log in after entering the correct login details, double-check that you are entering the right email address and password. If you’re not sure, reset your password at www.grammarly.com/resetpassword and try to log in again.
If you registered your Grammarly account using Google, Facebook, or Apple, select the corresponding option to sign in. If you prefer to set a password for your Grammarly account, you can do that by following the steps in How do I set a password if I registered using Google, Facebook, or Apple?
Note: If your organization is using single sign-on, please sign in by launching Grammarly through your identity provider (a platform that provides authentication services to your organization). If you are having problems with your identity provider, please ask your organization’s administrator to review the instructions in Add Grammarly to an identity provider.
If resetting your password didn’t help, or you registered your account using a different sign-in method, select the Grammarly product in the menu below to see the corresponding troubleshooting steps.
