Error: "Grammarly is temporarily unavailable!" on Android
If you see the error message "Grammarly is temporarily unavailable" while using Grammarly for Android, please try the following steps:
  1. Open your device’s settings, go to Network or Connections, and try to fix or reset network settings if such an option is available.
  2. Switch between Wi-Fi and cellular connections and see if the issue is only happening on a particular network.
  3. Close and reopen your keyboard.
  4. Log out and log back in to Grammarly for Android.
  5. Restart your device.
