Grammarly agent user guide
The Grammarly agent is a tool that ensures your writing is well-written and error-free. It helps you identify what is incorrect and also suggests ways to improve the clarity and quality of your communication. Whether or not you have a large amount of text, you can easily navigate the suggested edits.
Availability
This agent is currently available in docs for Pro and Plus users, and in Superhuman Go.
How to proofread your text
While writing, you’ll notice red underlines appear in your text. These indicate critical suggestions, such as grammar, spelling, or word choice issues.
To review critical suggestions:
  1. Hover over or click a red underline to open the suggestion card.
  2. Click the suggestion card to accept or dismiss the suggestion.
Note: The information below is exclusive to docs, our writing surface. To access the Grammarly agent in the browser extension, switch on Superhuman Go.
For a more comprehensive review, open the Grammarly agent by clicking its icon on the right side of the page:
In this view, critical suggestions will remain available. In addition, Grammarly will analyze your entire document and present recommendations in dynamic categories specifically tailored to your writing context:
Choosing each category will highlight the corresponding parts of your text. Hover over the blue dot to review the suggested paragraph-level rewrites one by one:
Once you review the suggested change to your paragraph, you can click Accept or Dismiss as you prefer. You can undo individual edits as needed.
