How to view your generative AI prompt history
If you would like to view or re-insert text from a previous prompt, simply tap the clock icon at the top of the Grammarly pop-up:
The top of Grammarly's pop-up window that shows the number of prompts left and the Prompts history button
When you open your prompt history, you will only see prompts you used in the application or on the website where you're currently working. In other words, you won’t see the prompts you’ve used in Microsoft Word when you open the prompt history in Gmail. Also, you will only be able to access prompts that were generated on the device you are currently using.
Note: If you don’t want Grammarly to save your prompts, you can switch off show recent prompt history in the Feature customization section of your Grammarly settings.
