How to switch to the Grammarly Keyboard on iPadOS 17 or newer using a hardware keyboard
With the release of iPadOS 17, Apple has changed how you interact with external keyboards and switch between various keyboards. Since this change falls under Apple's domain, our options to address it directly are limited.
As a workaround, you can switch to the Grammarly Keyboard by tapping the Show keyboard while your external keyboard is active, and then tapping the onscreen globe icon to switch the keyboard to Grammarly.
You can also submit a bug report to Apple so that the team is aware of this issue. Here is how to submit a bug report to Apple:
  1. Go to Apple's feedback page and choose iPad.
  2. Fill in the form and provide details about the issue, including the specific problems with the Globe key and the Grammarly Keyboard when using the Apple Magic Keyboard on iPadOS 17 or newer.
  3. Send your feedback to notify Apple of the issue.
