Grammarly's generative AI assistance is available on Android, iPhones, and iPads.
To use Grammarly’s generative AI on Android, please do the following:
1. Select the text segment that you’d like to improve. To do this, long-press on the text in question until the selection markers appear, then drag these markers to wrap the text you’d like to edit.
2. Once you have selected your text, tap Improve it:
3. You will see several options for how your text can be rewritten. Tap a prompt that suits your needs:
You can also create a custom prompt by entering it in the Tell us to... field.
4. When satisfied with the proposed rewrite, tap Insert to confirm the changes. This will automatically replace your original text with the updated version:
To use Grammarly’s generative AI features on your iPhone or iPad, follow these steps:
- Ensure that the Grammarly Keyboard is enabled on your iOS device.
- Highlight the sentence or paragraph you want to rewrite.
Tap Improve:
Note: The Improve button will only appear if two or more words are selected.
You can also choose different rewrite options, such as:
- Improve
- Rephrase
- Shorten
- Friendly
To generate a new rewrite if the first one isn’t quite right, tap the double-arrow icon:
To revert a change, just tap on the underlined text Grammarly suggested.
