The Go Enterprise License Agreement provides your organization with access to Superhuman Go and Grammarly and is designed to enhance team communication and streamline workflows. It boosts productivity across your organization by regularly adding new capabilities and integrations.
Review these sections below to understand how Go Enterprise works for your organization, how membership is managed, and how access to the features and agents is provisioned:
My Settings
My Settings section lets you manage your account’s personal information.
Profile
To update your personal information on the account, click the Edit button in the upper-right corner.
Since certain settings are managed via the linked Grammarly account, you’ll be redirected to the Grammarly Profile page.
To update the name on your account, follow these steps:
  1. Click Update next to the Name section.
  2. Enter the preferred First name and Last name.
  3. Save the changes by clicking Update.
You can review the permissions for the role associated with your account by clicking View permissions next to the Role section.
To update the email address for your account or delete an account, contact the Customer Care team.
Admin Settings
The Admin Settings section is available to admins only and allows you to manage your team subscription, members list, and roles across your suite of Superhuman apps.
General
To update your team name, follow these steps on the General page:
  1. Click Edit next to the team name.
  2. Enter the preferred name in the Team Name field.
  3. Click Save Name to update the team name across the apps.
Members
To invite your team members to join your subscription and gain access to Grammarly and Go, follow these steps:
  1. On the Members page, click + Members in the upper right corner.
  2. Enter up to 10 email addresses at a time by pressing space, enter, or tab after each email.
  3. Click Invite to confirm the action.
The number of available seats is shown above the list of current members and in the Invite Members window.
To cancel the pending invitation, click the three dots next to the email address in question and click Cancel Invite.
To remove a member from the subscription, click the three dots next to the email address associated with the account in question and click Remove User.
To update the role associated with the given account, follow these steps:
  1. Click the three dots next to the account in question.
  2. Choose Edit User from the dropdown menu.
  3. Click Save to confirm your action.
Groups
To create a group of members, follow these steps:
  1. On the Groups page, click the + Create Group button in the upper-right corner.
  2. Enter the Group Name.
  3. From the list, select the members you want to add to the group by checking the boxes next to their accounts.
  4. Click Create Group to confirm the action.
You can also create groups by adding team members’ accounts to the CSV template:
  1. Click the Create Groups via CSV button.
  2. Download the template to create one or more groups.
  3. Upload the completed template by clicking the Upload button.
  4. Click Create Groups to finalize the step.
Note: If team members have already been assigned to groups in the Grammarly-only subscription before joining the Go Enterprise plan, the list of groups will be migrated and synchronized with the Superhuman Groups page once you join the Go Enterprise subscription. After that, the member groups should be managed through the Groups page in Superhuman.
One member can belong to several groups. A team member should join the subscription in order to be added to a specific group. ​
To edit the group, click the arrow button next to it. On the page that opens next, you can delete the group by clicking the Delete Group button or add more team members to it by clicking the Edit Group button.
If you want to remove a team member from the group, click the three dots next to the member’s account and confirm the action by clicking the Remove from Group button.
Subscription
The Subscription page allows you to review the total number of seats for your subscription as well as the number of vacant seats that are currently available for distribution.
Apps
Manage Go
The Manage Go page allows you to customize how the Go assistant works for your team.​
The Web Search toggle controls whether the Go assistant and agents can access the public web. It can be set to on or off for the entire organization.
The Agent Sharing toggle determines if team members can publish agents internally, and it can be switched on or off for the entire organization.
The Superhuman Go toggle enables or disables the Go assistant for your organization. You can also enable the Go assistant for specific groups by selecting them from the list under the Add Groups section and confirming your choice by clicking the Apply Groups button.
Manage Grammarly
The Manage Grammarly page takes you to the Grammarly Home page, where you can adjust all the features, preferences, and associated tools for Grammarly.
Agents
The Agents page allows you to configure and manage the following list of agents:
  • Proofreader
  • Plagiarism Checker
  • Translate
  • Explain it
  • AI Detector
  • Paraphraser
  • Reader Reactions
  • Humanizer
  • Resume Buider
By double-clicking the row for the corresponding agent, you can open the page with the related details and configuration options.
Access to the agent can be assigned to All users, No users, or Custom by selecting the corresponding option from the dropdown menu in the Agent Access section. The custom option allows you to select the groups of members for whom the agent will be available. ​
The Agent details section provides information on the domains to which an agent is connected and a list of the apps where the agent operates.
Connectors
The Connectors page lets you manage all available Superhuman connectors to external sources. The library is constantly expanding, with new integrations added regularly.
Clicking on a connector will open the page for its granular controls of permissions and user access.
The Connector access section allows you to set its availability to Everyone, No one, or Custom.
Setting the Connector access to Custom will reveal the Configurations section. To change an existing configuration, click Edit next to it. To create an additional configuration, click + Add Configuration under the existing one.
Configurations allow you to specify member access, read and write permissions, OAuth scopes, and more.
The Connector details section provides information on the domains a connector is linked to and the apps in which the connector operates.
