How to create or edit documents on iPhones
As an iPhone user, you can access the Grammarly iPhone Editor directly from your mobile device by downloading Grammarly for iPhone.
Note: To start using the Grammarly iPhone Editor, you will first need to install the Grammarly Keyboard for iOS. Once you have installed the Grammarly Keyboard, you can start using the Grammarly iPhone Editor. You will also have the option to easily switch between the Grammarly Keyboard and your iOS keyboard anywhere that you type.
If you would prefer to use the Grammarly iPhone Editor without having to install the Grammarly Keyboard, please go to the Feature Request section to share your feedback.
This article covers:
Note: You can also access the Grammarly Editor from your iPad or desktop computer. For more information, see the Grammarly for iPad user guide or Grammarly Editor user guide, respectively.
Creating new documents and accessing existing documents
Once installed, open the Grammarly companion app and go to My Grammarly. On this page, you’ll be able to find the documents you’ve previously saved in your Grammarly account:
To create a new document in the Grammarly iPhone Editor, you have two optionsWrite or Import:
Write
  1. Tap the Write option in the Grammarly iPhone Editor app.
  2. A blank document will open, where you can begin typing your text.
Alternatively, you can copy text from a different app and paste it into the blank document to get started.
Import
  1. Tap the Import option in the Grammarly iPhone Editor app. This will prompt you to select a document from your files.
  2. Navigate through your files to locate and select the document you want to import.
Once you’ve selected the document, it will be loaded into the Grammarly Editor, allowing you to review and make any necessary changes.
Currently, the Grammarly iPhone Editor supports the following file formats:  PDF, Microsoft Word (.doc, .docx), OpenOffice (.odt), .txt, .rtf, Markdown (.md), TextPack and TextBundle, .opml, and many other formats from different iOS apps.
If you would like to see other file formats supported, please go to the Feature Request section to share your feedback.
Tip: You can also use the quick actions menu to create a new document by tapping and holding the Grammarly icon on your Home Screen and selecting New Document.
Documents that you create or edit in the Grammarly iPhone Editor will be available on your desktop computer in the Grammarly Editor at app.grammarly.com.
Downloading and sharing documents
After completing your document editing in the Grammarly iPhone Editor, you have the following options to export your text:
Download the document to your iPhone
Open the document that you want to download and tap the Share button. From there, you can choose one of the supported file formats, such as PDF (.pdf), rich text (RTF), plain text (TXT), Markdown (MD), Microsoft Word (DOCX), or HTML page (.html). The document will be saved to the Files app on your iPhone.
Send as Email
Tap the Share button within the document, and a menu of sharing options will appear. From the menu, select Send as Email. This will open the default email app on your iPhone. The edited document will be inserted into the body of the email.
All you have to do is provide the necessary recipient details, including the email address, subject, and any additional information required before sending the email.
Checking text
The Grammarly iPhone Editor on your device provides almost the same types of writing suggestions as on the computer.
Once you have finished writing your document or pasted your text into the Grammarly iPhone Editor, you’ll see the first suggestion just above the keyboard:
You can either tap on it to apply the change or swipe to ignore it.
If you’re on the Free plan, consider upgrading to Pro to increase your productivity and boost your communication. Visit www.grammarly.com/plans to see which advanced features you can access and choose the plan that suits you the most.
If you’d like to review the suggestions, tap the Grammarly icon that appears above the keyboard. This action will open revision mode and allow you to review and accept suggestions:
If you’d like to view a specific suggestion, tap on the underlined text, and Grammarly will automatically show the suggestion relevant to that part of the text.
You can switch back to the keyboard anytime by tapping the keyboard icon:
Note: The tone detector is not yet available in this product offering. If you would like to see this feature in the Grammarly iPhone Editor, go to the Feature Request section to share your feedback.
Checking text for plagiarism
If you have a paid subscription, you can check your document for plagiarism. To do that, tap More () in the upper-right corner and select the Plagiarism option.
Formatting text
Grammarly for iPhone also supports the following rich-text formatting options:
  • H1 and H2 headings
  • Bold, italic, and underlined text
  • Numbered and bulleted lists
  • Hyperlinks
  • Paragraph indents
  • Clear Formatting
To apply any of the formatting options, double-tap any word and drag the pins to select a specific part of your text. Then, tap the Aa button that appears in the lower-right corner of the text field:
Then, choose any formatting option you’d like to apply.
Keep in mind that the H1 and H2 headings, bulleted and numbered lists, and paragraph indent options will apply to the whole paragraph. The option to make the text bold, in italics, or underlined and the option to add a hyperlink will apply to the selected part of the document only.
To clear the formatting from the text that you have highlighted, simply tap the clear formatting icon, which is displayed as a capital “T” with a diagonal strike.
Tip: By highlighting your text, you can also access a quick actions menu that will allow you to copy, cut, paste, format, define terms, and more.
Adjusting goals
Grammarly can also help you achieve a specific goal with your text and ensure that it’s suitable for your intended audience.
To adjust your goals, access the options menu, select Goals, choose your preferred settings, and tap Done:
You can also turn on the option Show Set Goals for a new document. The Goals selection menu will appear anytime you start a new document:
Performance Report
If you want to view your performance report, tap on the three dots icon located in the upper-right corner of your screen and then select Performance from the dropdown menu. This will allow you to see your total score for the text, as well as the word count, readability score, and vocabulary, which includes unique words and rare words used in your text. This information can be very helpful in improving the overall quality of your writing.
Adjusting your settings
The option to update your Editor settings is not currently available in this product offering. However, you can still access and manage your language preference and personal dictionary. For more information about adjusting settings on iOS devices, check out this guide: Managing your keyboard settings in Grammarly for iPhone
If you are a Grammarly Pro, Grammarly Plus, Grammarly Business, or Grammarly for Education user, you can also deactivate certain Grammarly suggestions by going to the Writing Style page on a desktop computer. For more information about this feature, visit this page: How to deactivate certain suggestions in the Grammarly Editor
