Grammarly offers a browser extension for Chrome, Safari, Firefox, and Edge that allows you to check your text whenever you write online.
Note: If you also use Grammarly for Windows and Mac, the browser extension will be turned off by default but will remain active in Google Docs. For more information on how to use Grammarly in Google Docs, check out this article: Does Grammarly support Google Docs?
To check whether the extension is installed, take a look at the top bar of your browser. If the extension is active, you’ll see the Grammarly icon:
Note: If you use Chrome, you can pin Grammarly’s browser extension to your toolbar for easier access. To do that, click the puzzle icon in the upper-right corner of the browser window and then click the pin icon to add Grammarly to your toolbar.
Once the extension is installed, you should see Grammarly’s writing suggestions as you type on different websites.
Checking text
When you click into a text field, you should see Grammarly’s logo in the lower-right corner. As you start typing, Grammarly will begin to check your text dynamically, and the Grammarly icon will spin.
Note: Grammarly does not initialize in text areas smaller than 38 pixels in height.
When Grammarly finishes checking the text, the icon in the lower-right corner of the text field will show the number of suggestions:
Some of our suggestions appear as underlines directly in the text. To accept a suggestion, hover over the underlined text, then click on the suggestion that appears:
Other suggestions will appear one by one once you click the Grammarly icon in the lower-right corner of the text field. To accept a suggestion, click the corresponding button on the card that appears next:
If Grammarly flags an unfamiliar word and you’re sure it’s spelled correctly, you can either dismiss the suggestion by clicking Dismiss or add the word to your personal dictionary by clicking the book icon.
Note: If you’re a member of an organizational subscription, the list of suggestions will appear in a sidebar once you click the Grammarly icon in the lower-right corner of the text field.
You can also use Grammarly’s tone detector. To learn more, see this article: Using the tone detector in the Grammarly browser extension
Using generative AI
To start using generative AI, click the green lightbulb Screenshot 2024-02-01 at 17.44.38.pngnext to the Grammarly icon, then type a prompt. You can also choose from suggested generative AI prompts based on your unique context. To learn more, check out Introducing generative AI assistance.
If you have an individual Pro subscription, you can extend the power of advanced features to your teammates by adding more seats to your subscription. This helps your team stay consistent, save time, and focus on high‑value work. Go to the Members page to add your teammates.
Deactivating certain suggestion types
Note: This feature is only available in paid plans.
Certain types of suggestions, such as adding the Oxford comma and flagging passive voice, can be turned off. You can view and manage suggestions on the Your preferences page.
Keep in mind that if you deactivate a certain type of suggestion, it will be deactivated across all Grammarly product offerings you use.
If you’re on the Free plan, consider upgrading to Pro to increase your productivity and boost your communication. Visit www.grammarly.com/plans to see what advanced features you can access and choose the plan that suits you the most.
Using definitions and synonyms
Grammarly’s browser extension also includes various features to help you improve your writing, such as looking up definitions or synonyms.
These options are activated by default, but you can switch them on or off by clicking the Grammarly icon in your browser’s toolbar.
You can check the definition of a word on any website by double-clicking it:
When writing, you can find synonyms by double-clicking a word you wrote:
Adjusting language preference and managing settings
You can adjust your preferences by clicking the Grammarly icon in the text field. In the pop-up that opens next, click the gear icon:
Alternatively, click the Grammarly icon in your browser’s toolbar to update your preferences:
Here you can:
