If you’d like to avoid being charged after your free trial ends, make sure you cancel your subscription by following these steps:
  1. Sign in to your account and click on the Account tab in the left sidebar.
  2. Click on Your account → Subscription in the menu that appears next.
  3. Click Cancel Subscription at the bottom of the page.
  4. In the window that appears next, click Continue.
  5. Choose a reason for cancellation and click Cancel Subscription.
Note: If you’re using a mobile device, you can cancel your subscription at account.grammarly.com.
After canceling, your free trial will end immediately, and your account will be converted to the free version without any charges. Your data will not be lost, and you will maintain access to all of your documents.
  • If you don’t see the cancellation button, please make sure you’re signed in to the correct account. If you’re unsure which account you used to start a free trial, please review this article: Problems signing in
  • If you don’t have access to your account, please contact Support.
  • If you want to delete your account, follow the steps in this article: Delete your account
