Android Go devices are no longer supported
Mobile devices running Android Go are no longer supported due to the limitations of this operating system.
If you are experiencing an issue installing or using Grammarly on your Android device, please check whether it is running Android Go. To learn more, please refer to this article: Grammarly for Android will no longer be available on Android Go devices
