Explore Superhuman Go agents and connectors
Superhuman Go helps you move faster across all the apps, tabs, and tools you use every day. It brings two key building blocks into your workflow:
  • Agents: Specialized AI teammates that take instructions, act on the context around you, and can perform tasks, organize information, and deliver quick summaries so you can focus on what matters most. You can use pre-built agents or build your own to customize AI to your preferences.
  • Connectors: Integrations that link Superhuman Go with the apps you already use, such as Gmail, Google Calendar, and Jira. They give Go secure access to your data and let you take actions in those apps.
Together, agents and connectors let you get things done across your tools in one place.
Finding and managing agents and connectors
The Agent Store is your starting point for exploring agents available in Superhuman Go. You’ll also see a Connectors tab that opens the list of currently available apps you can connect with. Both libraries are constantly expanding, with new agents and integrations added regularly.
Where to find agents and connectors
Agents and connectors are available in the Superhuman Go browser extension for Chrome and Edge, in Superhuman Go for Windows and Mac, and on Superhuman Go for mobile.
They can also be accessed through Grammarly for Windows and Mac, and through the Grammarly browser extension for Chrome and Edge, after enabling Superhuman Go in settings.
Some agents are also available in docs, our new AI writing surface. To learn more, see Docs: Grammarly’s new AI writing surface—user guide.
How to add an agent
  1. Open Superhuman Go or go to go.superhuman.com and click the menu icon in the upper-left corner:
  2. In the Agents section, click See more:
  3. In the menu that appears, select Agent Store:
  4. Click Open next to any agent to learn more — see what it can do, what data it uses, and how it protects your privacy.
  5. When you’re ready, click Open agent or Install agent and follow the next steps. Many agents will guide you to add the connectors they rely on.
How to add a connector
  1. Open Superhuman Go or go to go.superhuman.com and open the left-side panel.
  2. Click Connectors in the lower-left corner.
  3. Search or browse for the connector you’re looking for.
  4. Click any connector to learn more — see what it can do, what data it uses, and how it protects your privacy.
  5. When you’re ready, click Sign in and follow the next steps. Adding a connector prompts you to sign in and connect the relevant app.
Once a connector is set up, you and your agents can access data and take actions across apps in one click — send an email, update a calendar invite, find a Jira ticket, and more.
Create your own agents
Beyond the agents in the Agent Store, you can now build your own. Create an agent in a simple chat with Go, or use the visual agent builder. With the agent builder, you create a custom agent by describing what it should do, giving it instructions, and choosing the connectors it can use. Your custom agents appear alongside built-in agents, and you can share them with your team.
To learn more, see Create custom agents in Superhuman Go.
Featured agents
Agents are your team of AI collaborators, built for the common tasks that fill up your workday, like summarizing long threads, drafting reports, or finding information across tools. Superhuman Go comes with a powerful set of default agents and lets anyone build custom ones tailored to your team’s needs, no code required.
Go
The Go agent embeds conversational AI into your workflow, so you can brainstorm ideas, refine text, or generate content in real time. It brings contextual assistance directly into your writing environment.
What you can do:
  • Prompt the AI to ask questions, generate drafts, or refine existing text.
  • The agent uses context from your active window or document (you can attach another window if needed) to tailor its responses.
Grammarly
The Grammarly agent helps polish your writing by identifying and explaining grammar, spelling, and clarity issues. It organizes feedback by category and provides quick actions to improve your text.
What you can do:
  • Review grammar, punctuation, and word choice issues in real time.
  • Accept, dismiss, or undo suggestions individually and at the paragraph level.
  • On paid plans, customize the suggestions you get from Grammarly.
Reader Reactions
The Reader Reactions agent simulates how your audience might perceive your message. It helps you refine tone, clarity, and overall impact before sharing your writing.
What you can do:
  • Predict how different reader types may respond to your text.
  • Review likely takeaways, points of confusion, and tonal mismatches.
  • Select or confirm an audience type, such as peer, manager, or client.
  • Review edits that make your writing clearer and more engaging for your audience.
Featured connectors
Connectors link Superhuman Go to the apps you already use, so agents can find information and take actions on your behalf. Here’s a closer look at some of the most popular connectors. New connectors are added regularly.
Google Drive
Quickly locate, summarize, and organize files across your Google Drive. This is perfect for when you need to find or understand a document fast.
What you can do:
  • Search and filter: Find files by name, keyword, or file type, such as Docs, Sheets, or PDFs.
  • Review details: Instantly see who owns a file, when it was last updated, and who can access it.
  • Stay organized: Track recent changes and locate files shared with specific people.
Gmail, Outlook & Calendar by Superhuman Mail
This connector helps you search, send, triage, and schedule across all your accounts.
What you can do:
  • Search across your accounts: Find emails, threads, attachments, and calendar events across your connected Gmail and Outlook accounts.
  • Get up to speed: Summarize conversations and quickly understand the decisions, requests, and next steps related to a customer, project, or topic.
  • Draft with context: Write new emails and replies in your voice, using relevant information from your inbox, calendar, and other apps connected to Go.
  • Send with confidence: Send emails, Smart Send them at the best time for each recipient, or undo a recent send.
  • Manage your inbox: Archive, label, move, trash, or mark messages as read, unread, or spam.
  • Manage your schedule: Find available meeting times and create or update calendar events.
Jira
Manage projects and issues directly from your workspace. The Jira connector keeps you connected to your team’s progress.
What you can do:
  • Find and summarize: Search by keyword, assignee, or project.
  • Track progress: See issue statuses and identify blockers.
  • Collaborate easily: Comment, reassign, or attach files.
  • Automate workflows: Move tasks or perform bulk updates where allowed.
  • Analyze performance: Generate reports on issue volume, sprints, and workloads.
More connectors
Superhuman Go supports a growing library of connectors beyond those above, including Google Contacts, Confluence, GitHub, Zoom, and more. Browse the Connectors section of the Superhuman Store to see everything available and add the ones your team uses.
