Can I sign up for beta testing of Grammarly for Android?
Yes! You can sign up for beta testing on your mobile device by following these instructions:
  1. Open the Google Play Store app on your Android device.
  2. In the search bar, type “Grammarly” and select the Grammarly app from the search results.
  3. On the Grammarly app page, scroll down to find the section labeled Join the beta.
  4. Tap the Join button. You may see a confirmation message about becoming a beta tester.
  5. After joining, it may take some time for you to receive the beta updates.
  6. Log in again to your Grammarly account for the changes to take place.
Note: Beta software may contain bugs or other issues that have not yet been identified. If you decide to participate in the beta program, we'd appreciate your feedback and assistance throughout the testing period. You are welcome to submit a request whenever you encounter a technical issue related to the beta version of our app.
