Included in: Grammarly Enterprise plans
Managed by: Admins
Grammarly is committed to strong data privacy principles for all users. Enterprise customers can set additional restrictions on what content or data Grammarly can access.
The client apps controls feature allows Enterprise admins to manage the availability of different Grammarly product offerings for members of their organization’s subscription.
If the availability setting is set to “Managed,” members of the organization’s subscription will not be able to download and install the corresponding Grammarly application independently. In this case, that application can only be installed in a centralized way using a managed software solution or deployment mechanism.
If the availability setting is changed to “Blocked,” the corresponding Grammarly application will not work for the affected members.
The availability settings can be set for the following Grammarly products:
  • Grammarly for Windows
  • Grammarly for Mac
  • Grammarly browser extensions
  • Grammarly for Mobile
Interested in upgrading to an Enterprise account? Contact our Sales team.
To configure client apps controls, follow these steps:
  1. Go to your admin Home page and open the Organization tab.
  2. In the Enterprise security section, select Client apps.
  3. To change the availability of a specific Grammarly application, click on the Available setting next to it and select Managed or Blocked from the dropdown menu:Access setting.png
  4. In the window that opens next, select who the access setting should be set for:
    • If you want to restrict the installation or block a Grammarly application for all members of your organization’s subscription, select Entire organization.
    • To restrict the installation or block a Grammarly application for specific member groups, select Specific groups, and choose the groups this should apply to. Optionally, you can select Require admin permissions to edit groups if you want to limit the ability to delete the specified group or remove members from that group only to admins. You can learn more in this article: How to organize members into groups
  5. Click Save.
You can always change the availability settings on the Client apps page.
Related articles
