Note: Grammarly is now part of Superhuman, a suite of AI tools that includes Go, Grammarly, Coda, and Mail. If you are a Superhuman user, please check out this article: Problems signing in to Superhuman
I forgot my password
To reset your password, request a password reset email by clicking this link, entering your email address, and pressing Send me reset instructions:
A screenshot of a password reset page
The email should arrive within about a minute and contain a link that will bring you to a page where you'll be asked to create a new password:
In case you experience any issues with resetting your password, please review these articles:
  • If you don't receive the password reset email, check this article for more information.
  • If the password reset link redirects you to the login page, follow these steps.
  • If the issue persists after resetting your password, we suggest following the instructions from this article.
You may also find these instructional videos helpful:
Note: If you registered using Google, Facebook, or Apple as a sign-up method, please select the corresponding option at https://www.grammarly.com/signin or in your preferred Grammarly product. However, if you prefer to create a separate password for your Grammarly account, you can do so at https://www.grammarly.com/resetpassword.
If you no longer have access to the email address associated with your account, check this article.
I don't remember my paid account login email
  • You can search every email account you use for the word "Grammarly" to find any emails we've sent you.
  • You can also try entering any other email addresses you might have used to create an account in the password reset form. If there is an account associated with the email you entered, you’ll receive password reset instructions.
If you still can't locate the login details for your paid account, please use this form.
I don't remember my free account login email
  • Search every email account you use for the word Grammarly to find any emails we've sent you.
If you no longer have access to the email address you signed up with and don't remember your password, you will need to create a new account with your new email address.
