The plagiarism checker is turned off by default. For steps on how to check your document for plagiarism against an index of publicly accessible websites and major proprietary databases, please select one of the supported product offerings below:
Currently, the plagiarism checker and AI detector features are available in Superhuman Go for Windows only in Microsoft Word.
To review your text for plagiarism, open the Authorship thumbprint in the lower-left corner of any Microsoft Word document and select Check for AI & plagiarism.
The plagiarism checker and AI detector features are available in Superhuman Go for Mac only in Microsoft Word.
To review your text for plagiarism, open the Authorship thumbprint in the lower-left corner of a Microsoft Word document and select Check for plagiarism and AI text.
In the Superhuman Go browser extension for Chrome and Edge, the Plagiarism Checker is available as an agent. To enable it, follow these steps:
Open the Superhuman Go assistant and click Agents:
Select Agent Store:
Search for Plagiarism Checker and click the agent to add it.
Once added, the Plagiarism Checker agent will always remain available in the agents’ panel unless you choose to remove it.
If you're using the Grammarly Editor, open or create a new document and click Check for AI text & plagiarism in the upper-right corner:
The plagiarism checker in Grammarly for Windows is available only in Microsoft Word.
To check your text for plagiarism in Grammarly for Windows, open a document in Microsoft Word, click on the Grammarly widget, and choose Check for plagiarism and AI text in the lower-right corner.
Currently, the plagiarism checker and AI detector features are available in Grammarly for Mac only in Apple Pages and Microsoft Word.
To open the plagiarism checker, click on the Grammarly tab on the right side of the screen and click Review all suggestions:
In the window that appears next, click on the quotation marks icon at the top:
If you’re using the Grammarly browser extension in Google Docs, open the Grammarly sidebar and click Plagiarism in the lower-right corner:
If you’re using the Grammarly iPad Editor, open or create a new document and click the Plagiarism button in the lower-right corner:
