Before you download and install this app, make sure Grammarly is compatible with your mobile device. We support all iOS devices running iOS 14 or newer.
Note: If you are an iPad user, check this article for more information on Grammarly for iPad.
To begin the installation, click this link or open the App Store on your iOS device and search for “Grammarly.”
Then, click Install next to the Grammarly listing and download the app on your device. Keep in mind that this app allows you to use Grammarly as an editor, as a keyboard, and as a browser extension in Safari.
Once the app is downloaded and installed, click Get Started. If you already have a Grammarly account, tap Log in to existing account and enter your login credentials. If not, tap Continue with email to create an account.
Note: If you used Google or Apple to create your Grammarly account, or you need to create a new account using one of those sign-in methods, tap the corresponding option. If you already have a Grammarly account linked to Google or Apple, but you would prefer to sign in with an email address and password, please request a password reset email here.
If you created your Grammarly account with Facebook, select Log in to an existing account and choose Facebook as the sign-in option.
Next, follow the on-screen instructions to finish setting up Grammarly.
For more information on how to check your documents using Grammarly for iPhone, check this page
If you’d like to take advantage of the Grammarly Keyboard for iOS, visit this page for more information.
If you want to give Grammarly for Safari on iPhone a try, please check out this article
