Requirements
- Identity provider account with access to the administrator console
- Grammarly Business, Grammarly Enterprise, or Grammarly for Education account with the admin role or a designated custom role
Select your identity provider to view the instructions on configuring it for Grammarly:
If your identity provider is not on the list, you can configure it for Grammarly manually using the following parameters:
  1. Single sign-on URL: https://sso.grammarly.com/saml/assertion
  2. Audience URI/SP Entity ID/Issuer: https://sso.grammarly.com/saml/metadata
  3. Name ID format: EmailAddress
  4. Name ID / Application Username / Unique Identifier: Email
  5. Required attributes/claims:
    • EmailAddress
    • FirstName
    • LastName
  6. Optional attributes/claims:
Grammarly SSO also supports alternative attribute and claim names to be compliant with standards such as InCommon. Below is a list of alternative attributes/claims that can be used:
  • EmailAddress: mail, urn:oid:0.9.2342.19200300.100.1.3
  • CommonName: commonName, cn, urn:oid:2.5.4.3
  • FirstName: givenName, urn:oid:2.5.4.42
  • LastName: surname, sn, urn:oid:2.5.4.4
After you have the Grammarly SAML app set up in your identity provider, please see the following article on how to enable SSO for your account: Set up SAML single sign-on
