System requirements: Grammarly for Android is compatible with mobile phones and tablets running Android 9.0 or newer.
To begin the installation, open the Google Play Store on your Android device and search for Grammarly. You can also go directly to the Grammarly - Writing Assistant installation page
In the Google Play Store, tap Install next to the Grammarly - Writing Assistant listing, download the app to your device, and follow the onscreen instructions to finish the installation and set up Grammarly.
To learn more, check out Introducing Grammarly for Android.
