Included in: Grammarly Business, Enterprise, and Grammarly for Education plans
Managed by: Admins and members with designated custom roles
Setting up SAML single sign-on (SSO) will enable your team members to log in to Grammarly through a third-party identity provider, eliminating the need to maintain separate passwords for Grammarly.
To enable SAML single sign-on, follow these steps:
  1. Add Grammarly to your identity provider.
  2. Sign in to your Grammarly account and go to the Authentication page.
  3. Click Configure.
  4. Fill in the necessary fields with the parameters from your identity provider.
  5. Click Test SSO. If the test is successful, click Activate SSO.
If the SSO test fails, please double-check the Grammarly settings in your identity provider and the values you entered on the Authentication page. If you encounter any issues, please look for a troubleshooting article on this page: Resolve Issues
Once SSO is activated, access to your organization’s subscription will be defined by access assignment in your identity provider.
Team members who are already part of your organization’s subscription won’t be able to log in to Grammarly until you assign the Grammarly app to them in your identity provider.
To add new team members to your organization’s subscription, you need to assign the Grammarly app to them in your identity provider. If you assign the app to someone who does not have a Grammarly account, it will be created for them when they sign in via SSO.
Note: You can also send invitations to team members from your Grammarly admin panel as described in this article: Invite team members. However, they won’t be able to join your organization’s subscription until they are granted access to Grammarly in the identity provider.
