Grammarly for Windows and Grammarly for Mac user guide
Using Grammarly for Windows or Grammarly for Mac, you can access Grammarly’s writing suggestions across a wide array of applications and websites.
Before installing Grammarly for Windows or Grammarly for Mac, ensure that your computer meets the system requirements
Jump to a topic:
Grammarly for Windows offers two interface options: the floating Grammarly widget that appears next to the text fields you’re writing in, and the newest Grammarly tab on the right side of your screen, which also features AI chat functionality.
Using the Grammarly for Windows tab with AI Chat
Accessing AI Chat
To switch to using the Grammarly tab with AI Chat, follow these steps:
  1. Find the Grammarly icon in the system tray in the lower-right corner of your screen, right-click it, and choose Settings.
  2. Turn on the Use docked chat launcher option:
Using AI Chat
To start reviewing suggestions, click the Grammarly tab on the right side of your screen and select Review suggestions:
You can also type your prompt directly in the “Ask AI” message box. AI Chat will use the context from your active window to tailor its response.
You can ask AI Chat for:
  • Content generation (emails, summaries, blog drafts, etc.)
  • Feedback or suggestions
  • Help with rewriting, tone adjustments, and clarity
Note: You can use up to 1,000 prompts per day. If you reach your limit, AI Chat will reset the next day.
To use preset quick prompts, select the text you’d like to improve, click the blue sidebar that appears on the left, and select one of the options available at the top of the suggestion card:
You can also type a custom prompt by selecting Revise with AI. To use the generated text, click Accept.
Using the Free plan? Upgrade to Pro to take advantage of advanced writing suggestions and more. Go to www.grammarly.com/plans to compare what Pro has to offer and choose the plan that works best for you.
Using the Grammarly for Windows widget
Checking text
After installing the application, open any app or website on your computer and start typing—a floating Grammarly widget should appear on your screen. When Grammarly detects a writing issue, it will underline the problematic word or phrase automatically. You’ll also see the number of identified issues on the widget:
A sentence written with several typos and Grammarly underlines words in red; in the lower-right corner of the image, Grammarly widget shows the number of text issues identified
When you’re ready to check your writing, click on the underlined word or the floating Grammarly widget to see the suggestion.
Note: In Microsoft Word, Grammarly may show a different interface with a list of suggestions. This interface allows you to review suggestions for the next 10 pages based on your cursor’s position. To view suggestions for other pages, move the cursor elsewhere in the text.
Click on a suggestion to accept it. You can learn more by clicking the three dots on the card. To dismiss an unhelpful suggestion, click the trash bin icon.
How to use generative AI features
To start using Grammarly’s generative AI features, click the lightbulb icon, then type a prompt. You can also choose from the suggested prompts Grammarly offers based on your unique context.
This image shows already-clicked lightbulb icon and the opened Grammarly panel with a text field to add your prompt.
Note: Each Grammarly user has a set number of prompts they can use a month. Each time you type something into the prompt field or select one of the suggested prompts generated by Grammarly, this counts toward your usage limit.
You can also rewrite text by highlighting the relevant part and clicking the lightbulb icon or a pencil icon that appears.
To transfer the generated text to your text field, click Insert:
The image shows Grammarly's generative AI assistance panel with a generated short message to welcome a new colleague. Under the generated text, there are Insert, Retry, and Copy options. Right underneath, there are additional quick prompts to use.
If you’re an individual Pro subscriber, you can share access to the advanced features with your colleagues and use the benefits together. Upgrading to a team plan can help boost your team’s productivity and reduce repetitive writing tasks. Go to the Members page to add your teammates.
Moving the Grammarly widget
Grammarly now features anchor points around text boxes and window corners, allowing the widget to stay fixed when minimized. This way, you’ll always know where to find Grammarly.
If the initial location overlaps an important function, you can drag the widget to another anchor point, identified by small blue icons. As you approach a new anchor, the dot will expand, pinning Grammarly to that location.
The Grammarly widget is clicked on and dragged to one of the anchor points on the screen that appear as blue dots
Grammarly for Windows remembers your selected window location per app or website.
When you open Grammarly to check available suggestions, you can move the window to any location on your screen. If you click the X in the upper-right corner or navigate to another window, Grammarly will return to its anchored position.
Using Grammarly’s tone detector
To check the tone of your message, make sure it contains between 150 and 2,000 characters. Once you’ve done that, you will see an emoji on the floating Grammarly widget that indicates the tone of your writing. Click the emoji to find out more about the tone of your message.
If you’d like Grammarly to stop checking the tone of your writing, click the floating Grammarly widget and then click the gear icon. In the Customization menu, switch off the Detect tone in my writing setting.
To learn more, see this article: Meet Grammarly’s Tone Detector
Deactivating certain suggestions
If you are a Grammarly Pro, Grammarly Plus, Grammarly Business, or Grammarly for Education user, you can deactivate certain types of suggestions. To do that, open your browser, go to Your preferences page, and switch off a specific group of suggestions. Doing so will deactivate this group of suggestions across all Grammarly product offerings you use.
Changing your language preference
Grammarly offers five dialect options: British English, American English, Canadian English, Australian English, and Indian English. Your language preference is set to American English by default. To change it:
  1. Click the floating Grammarly widget and then click the gear icon in the upper-right corner.
  2. Go to Writing Style and select your preferred option next to I write in.
Alternatively, you can go to your Language settings page to update your language preference. Keep in mind that updating your language preference will apply this setting to all Grammarly product offerings you use.
To learn more about language preference and differences between dialects, see this article: How to Select Your English Dialect
Managing your account settings
Access your settings in Grammarly for Windows by clicking the Grammarly widget and selecting the gear icon in the upper-right corner. In this menu, you can:
  • Access your account settings
  • Manage your language preference
  • View applications where Grammarly was turned off
  • Update your writing style and activate Grammarly’s tone detector
Grammarly for Mac
