Introducing generative AI assistance
We build AI that transforms how people communicate, making writing clearer, more credible, and more impactful—no matter where you work or write.
You can leverage AI across most of our product offerings—this guide can help get you started.
This article covers:
  • Go and our AI agents
  • On-demand generative AI assistance
  • AI features in our mobile product offerings
Available in: Grammarly for Chrome, Grammarly for Edge, and docs, our new AI writing surface
Superhuman Go is the proactive AI assistant that integrates AI directly into your workflow and offers help based on what you’re working on. Whether you need to ask a question, brainstorm ideas, receive recommendations, draft content, or polish existing text, Go is designed to support you in real time.
Along with Go, you can add more agents to your Superhuman experience—each agent can help you perform tasks faster, organize information, and deliver quick summaries so you can focus on what matters most.
Learn more:
  1. Superhuman Go Agents
  2. Docs, our new AI writing surface
Available in: Grammarly’s browser extension for Chrome and Edge, the classic version of the Grammarly Editor, and Grammarly for Windows and Mac
Our on-demand generative AI assistance helps you quickly compose, rewrite, ideate, and reply. It’s context-aware and adapts to your personal voice, offering relevant, personalized suggestions that respect your agency and let your authenticity shine.
To start, select the text you’d like to rewrite—depending on the Grammarly application you’re using, you’ll either see a pencil or lightbulb icon or a sidebar to the left of the paragraph. Once you click, Grammarly will automatically suggest ways to improve this text. You can prompt our generative AI to change the text in any way you prefer.
Learn more:
If you’re on the Free plan, consider upgrading to Pro to increase your productivity and boost your communication. Visit www.grammarly.com/plans to see what advanced features you can access and choose the plan that suits you the most.
You can also use Grammarly’s generative AI to start working on a document or task. All it takes is a prompt in AI Chat, available on Grammarly for Mac, or via the generative AI feature in Grammarly for Windows. Similar to agents described above, AI Chat can help you come up with an outline or edit existing text alongside you.
If you use the Grammarly Editor, open the Write with generative AI tab and ask AI for help with the outline or ideas.
Learn more:
Grammarly’s generative AI features are available on both Android and iOS devices. Learn more here: How to use Grammarly’s generative AI on my mobile device
