If you have a Grammarly or Coda account, you can log in to Superhuman with your existing credentials by following these steps:
- Go to id.superhuman.com/signin
- Enter your email address and click Continue.
- You will then be redirected to Grammarly or Coda to log in. Once you do that, you will be redirected back to Superhuman.
Note: If you have two-step verification or single sign-on (SSO) enabled for your Grammarly or Coda account, you will need to complete that process to log in to Superhuman.
If you do not have a Grammarly or Coda account, you can sign up for Superhuman by following these steps:
- Go to id.superhuman.com/signup
- Enter your preferred password and your name.
You will be prompted to verify your email address by entering a six-digit verification code sent to your email address.
Note: You can also sign up using Google, Apple, or Microsoft by selecting the corresponding option at sign-up.
If you have a Superhuman Mail account, you can use the associated email address to create a Superhuman account by following the steps above.
