If you have a Grammarly or Coda account, you can log in to Superhuman with your existing credentials by following the steps below:
  1. Go to https://id.superhuman.com/signin
  2. Enter your email address and click Continue
  3. You will then be redirected to Grammarly or Coda to log in. Once you do that, you will be redirected back to Superhuman.
Note: If you have two-step verification or single sign-on (SSO) enabled for your Grammarly or Coda account, you will need to complete that process to log in to Superhuman.
If you do not have an account with Grammarly or Coda, you can sign up for Superhuman by following these steps:
  1. Go to https://id.superhuman.com/signup
  3. Enter your preferred password and your name.
You will be prompted to verify your email address by entering a six-digit verification code sent to your email address.
Note: You can also sign up using Google, Apple, or Microsoft by clicking on the corresponding button.
If you have a Superhuman Mail account, you can use this email to create a Superhuman account by following the steps above.
