With Grammarly, your writing will remain polished even on the go. Whether you’re typing a quick text, writing an important email, or adding on to an existing document, Grammarly for iPhone can support you in your writing endeavor.
Grammarly for iPhone is several apps in one—by installing it once, you’ll have access to the Grammarly Keyboard for iOS, the Grammarly iPhone Editor, and the Grammarly browser extension for Safari on your iOS device.
Note: If you are an iPad user, check out this article: Grammarly for iPad user guide
Before downloading and installing Grammarly on your iPhone, make sure your device is running iOS 14 or newer. Grammarly for Safari on iPhone is available on devices running iOS 15 or newer.
Note: To start using the Grammarly iPhone Editor, you will first need to install the Grammarly Keyboard for iOS. If you would have preferred to use the Grammarly iPhone Editor without installing the Grammarly Keyboard, please share your feedback in the Feature Request section.
Once installed, follow the on-screen instructions to set up Grammarly and log in using your account credentials. You will then access Grammarly’s companion app, where you can:
  • Create or edit existing documents
  • Set up and personalize the Grammarly Keyboard for iOS
  • Manage your language preference and personal dictionary
  • Access your weekly Grammarly Insights report
  • Provide feedback and contact support
  • Review our Privacy Policy and Terms of Service
If you’re on the Free plan, consider upgrading to Pro to unlock the benefits of the advanced writing suggestions. Visit www.grammarly.com/plans to see what Pro has to offer and choose a plan that best suits your needs.
To find out more about creating or editing documents on your iPhone, review this article: How to create or edit documents on iPhones
If you’d like to learn more about the Grammarly Keyboard for iOS, check out this guide: How does the Grammarly Keyboard work on iPhones?
For additional details on the Grammarly browser extension for Safari on iOS, review this page: How does Grammarly for Safari on iOS work?
