I forgot my password
To reset your password, go to id.superhuman.com/reset-password, enter your email address, and click Send reset link.
The email should arrive within about a minute and contain a link that will bring you to a page where you’ll be asked to create a new password:
In case you experience any issues with resetting your password, see these articles:
Note: If you registered using Google, Microsoft, or Apple as a sign-up method, select the corresponding option at id.superhuman.com/signin.
I don’t remember my account login email
  • You can search every email account you use for the word “Superhuman” to find any emails we’ve sent you.
  • You can also try entering any other email addresses you might have used to create an account on the Password Reset page. If there is an account associated with the email you entered, you’ll receive password reset instructions.
  • If you have a paid account and still can’t locate the login details, visit this Support article.
I don’t have access to my email address
  • If you no longer have access to the email address associated with your paid account, please submit a support request.
  • If you no longer have access to the email address associated with your free account and don’t remember your password, you will need to create a new account with your new email address.
Note: If you are a Grammarly user, please check out this article: Problems signing in to Grammarly
