When using Grammarly, you may occasionally encounter a CAPTCHA—short for Completely Automated Public Turing test to tell Computers and Humans Apart. CAPTCHAs help us verify that you’re human and protect Grammarly from automated bots.
If you’re experiencing issues with a CAPTCHA, try the following solutions:
  • Turn off your VPN or proxy:
    • VPNs and proxies can sometimes trigger CAPTCHA requests. Try deactivating them temporarily and refreshing the page.
    • If you’re unsure whether you’re using a proxy, you can check by following the steps in this article: How can I tell if I use a proxy server?
  • Ensure your browser is up to date. Check your browser settings for available updates.
  • Deactivate browser extensions temporarily. Some extensions may interfere with CAPTCHA. Try turning them off and refreshing the page.
  • Log in using a different browser, network, or device.
Alternatively, you can solve an audio challenge instead of a visual one. To do so, click the headphone icon at the bottom of the CAPTCHA window.
To stop seeing these prompts in the future, we suggest setting up two-step verification for your account via a third-party authenticator app:
  1. Sign in to your Grammarly account, click Your Account in the left-side panel, and select Two-Step Verification, or go to account.grammarly.com/security/mfa.
  2. Click Turn On. You may be asked to verify your account again by entering your password and a 6-digit code sent to your email address.
  3. Select a third-party authenticator app.
  4. Scan the QR code using your preferred third-party authenticator app.
  5. Click Next.
  6. Enter the verification code from within your authenticator app.
  7. Click Verify to activate two-step verification.
Important: Save the backup codes you’ll see in the pop-up menu that appears during the activation of two-step verification. If you lose access to your phone or authenticator app, a backup code is the only way you’ll be able to sign in to your Grammarly account on new devices.
