Learn how to automate your workflows. Set up triggers, actions, and filters to create powerful automation rules.
In Superhuman Docs, automations allow you to streamline your workflows and automate repetitive tasks. Whether you're managing projects, tracking data, or collaborating with a team, automations can help you save time and increase productivity.
Let’s make your doc as powerful as an app with automations! 💥
Add an automation to your doc
To add an automation to your doc, follow these steps:
Click the three-dot menu in the upper-right corner of your doc
Select Doc settings from the list
Click into Automations
Click Add Rule
Build your automation rule! 🎉
When and Then: automation basics
Automations have two required steps: When and Then.
Step 1: When
The first step in an automation is the When. This step informs Superhuman Docs when to trigger the automation. You can select from the following triggers:
Row changed: The automation will start when a row in a specified table changes. With this option, you can specify any editable column. Columns that contain formulas cannot trigger automations.
Formula changes, edits to canvas columns, and comments will not trigger automations with this type of trigger.
Time-based: The automation will run on a specified cadence. You can select from the following options for your automation cadence:
Hourly (run the automation every 1, 2, 4, 6, 8, or 12 hours)
Daily (run the automation every day at a specific time)
Weekly (run the automation every week on a specific day, at a specific time)
Monthly (run the automation on the X day of the month, at a specific time)
Monthly automations won’t run on the 29th, 30th, or 31st in months without those days.
Form submitted: The automation will run when someone submits a form to a form results table. Check out this article to learn more about Forms.
Webhook invoked: The automation will run when a POST request is made to a specified URL. You can learn more about Webhook-invoked automations here.
💡 You also have the option to choose when your automation will expire. By default, automations never expire. But you can choose to change this via the Expiration dropdown in the When step of the automation.
Once expired, the rule will automatically disable itself. In other words, the automation will still be visible in your list of automations, but it will be toggled to off.
Step 2: Then
Then is the action you want Superhuman Docs to take when the automation is triggered.
In this step, you can write a formula to tell Docs specifically what you want it to do, or you can select from the dropdown menu of options:
Make changes to tables by adding, modifying, deleting, or duplicating rows
Duplicate pages in your doc
Notify people in the doc through Superhuman Docs' notification tool
change control values
Manipulate the data you’re receiving from other sources via Pack actions, or send notifications via Packs like Slack and Gmail.
Additional automation components
If and And Then: optional automation steps
There are two other optional steps that can make up your automation: If and And Then.
If: the conditional step
The If step is where you can specify a condition that determines whether or not the automation continues once triggered.
To add an If condition to your automation, click Add a condition between your When and Then steps.
And Then: add more actions
Automations in docs can include multiple results in sequence after an automation is triggered. If you want to add multiple steps to your automation, add an And Then step:
In your automation, hover your mouse on the line between your Then step and the Test rule button. This line will then highlight blue and display a + button.
Click the + button that appears on hover. You can add as many And Then’s to your automation as you like!
Configure your And Then step! 🎉
Take actions as...
The final step to configure in your automation is who the automation should take actions as. At the very bottom of the Automation side panel, you’ll see a dropdown menu containing two options:
Take actions as Automation Bot: Automations that are set to take actions as Automation Bot can be edited by anyone with edit access in your doc. You cannot use private Pack accounts with this configuration, only shared Pack accounts. Learn more about private and shared Pack accounts here.
Take actions as yourself: If you choose this, you become the automation "owner." This automation cannot be edited by anyone else but you. If you want to take actions with a private Pack account, you’ll need to select this setting as part of your automation configuration. Learn more about private and shared Pack accounts here.
ℹ️ As noted above, automations can be set to take actions either as Automation Bot, or as the automation "owner." By default, the owner of the automation is the person who creates the automation. So what if someone else created the automation in the first place, but you now want the automation to take actions as you rather than as that original person. In that case, you can claim ownership of the automation by clicking on the Take actions as section of the automation, and choosing Claim rule ownership.
Test your automation rule
After you build your automation, you can press the test rule button below your automation’s last step to make sure each of your steps is configured correctly.
When you run the test, look for:
Green check marks: this means the automation can move forward with the next step
Returns: the Returns results at the bottom of each rule let you see what each step returns to make sure that the automation is picking up the right information based on the current configuration.
💡 Tip: For row change automations, the best way to test is by turning on the automation and doing a manual test. This is because the Test Rule button selects a row at random, and it may not meet the criteria of your automation.
Step 1 Result
If you want to add an if condition using the details from the rows that meet the criteria of your when trigger, or if you want to reference the details from those rows in your Then or And Then steps, you’ll need to use Step 1 Result in your formula.
Step 1 Result is a fancy way of calling out the results of your When criteria in a formula.
Check out this tip for a quick example on how to use Step 1 Result in your automations.
Automation activity and errors
The Activity tab holds the audit trail of every time the automation runs (including tests). To access the activity tab, open up your automation rule and click Activity, located under the title of your automation rule
If there was an error in your automation run, you’ll see a red exclamation mark. You can click on any of those entries to see more details. This will help you know where to make corrections.
Tip: You may also receive in-doc notifications about failed automations. You can click on the notification from the notification panel, and the failed automation will open on the right.
Common errors
Below are some common errors that you may see in the activity tab of your automation, along with some recommended troubleshooting steps.
| Error type | Suggested troubleshooting |
Unable to modify row |
If your automation is adding or modifying rows, make sure the columns being edited are not already set by a formula, as this will cause the automation to fail. You’ll need to check each column that's being set or edited by the automation. |
Disabled buttons |
This error occurs when the automation is attempting to push buttons that have been disabled. If you have an automation that presses every button in a button column, for instance, make sure you filter out any rows with disabled buttons. You can use the advanced formula editor in your automation to adjust this. Just click the f symbol to open the formula editor, then add a filter formula between the table and button reference. For example, RunActions(Table.Button) can be adjusted to RunActions(Table.Filter(Inverse of disable formula).Button). |
Automation timed out |
If your automation is very calculations heavy (e.g. processing 100+ rows at one time), you may benefit from pulling the automation logic out into a button and having the automation press that button instead. Also, try to narrow down calculations so that you’re only processing rows that need to be processed using Filter() formulas. |
Insufficient access |
If your automation is running a Pack action that requires a private account vs a shared account (e.g. post message to Slack, send email, etc.), make sure you change the automation to run as yourself vs the Automation bot. Refer to the "Take actions as..." section above for more details on this. |
Automation triggering another automation |
At the moment, automations cannot trigger other automations. This is to prevent infinite loops which have the potential to break your doc. Instead, have your automation run multiple Then statements by clicking the + button underneath your first Then statement to create an And Then step. |
How do automation rules work with formulaic columns?
Currently, the row change trigger can only work with columns that are manually updated (via direct edits, button-generated edits, or API edits). They do not work on value changes in columns that are populated by formulas.
Can automation rules trigger other automation rules?
Not at this time. As a workaround, you can use And Then statements to add multiple actions to your automation rule that will run in sequence!
Can I add a description to my automation?
Absolutely! Descriptions are a great way to help others - and your future self - quickly understand the purpose of an automation. After you've set up an automation, a description will be added automatically. But you can always edit this description by opening the automation, then clicking into the text field directly beneath the title.
Is there a limit to how many automations I can run?
If your workspace is on the Free or Pro tier, you will have a limited quota of automations per month, per doc. There are no such limits on the Team or Enterprise tiers. You can read more about the specific limits - and find info on upgrading to a higher tier - here.
How do I turn my automation on or off?
You can switch individual automations on or off by either...
Right-click on the automation in the list, and select Turn off or Turn on
Open the individual automation, and toggle the on/off switch near the automation title
You can also turn off all automations in the doc at once. Open the automations panel, click the three-dot menu at the top, select Turn off all, then confirm by clicking Turn off rules.
Does my plan type dictate automation speed?
Nope! No matter what plan you are on, your automations will run at the same speed.
When triggered, do automations run instantaneously?
Automations will run promptly, but may not be instantaneous. Superhuman Docs often has to run computations and complete other steps in order to action your automation.
How can I reference the results of the first step of my automation?
If you want to reference the details from the results of your first step (When criteria) in your If, Then, or And Then steps, you’ll need to use Step 1 Result in your formula.
Can row change automation triggers work on Cross-doc tables?
Yes! The caveat is that Cross-doc table values only change upon a re-sync of the sync table. However, once those row values change after the sync is complete, the automation will be triggered.
Can I pull the activity log of ALL the automations in my doc up at once?
Currently, the only way to view automation activity is to check the Activity tab within each individual automation rule. There is not a way to view all automation activity across all automations in a doc.
I am using the Test Rule button to test out a row change automation, and it’s not behaving as expected. Why?
The Test Row button pulls a random row to test your automation on, which may or may not meet your automation rule’s trigger criteria. Instead, we recommend toggling the rule to “ON” and performing a manual test.
Is there a way to force stop my automation from running after it’s been triggered?
No, we don’t currently support force stopping your automations once they’ve been triggered.
I want to edit the steps of an automation but they are greyed out and uneditable. How can I change this?
The steps of an automation can only be edited by the automation "owner." We consider an automation to be "owned" by whichever account is used for the Take actions as portion of the automation. Therefore, you can take over ownership of an automation by changing who the automation is set to Take actions as. Within the automation, click on the Take actions as section at the bottom, and choose Claim rule ownership. Now, the rule will be set to Take actions as [yourself]. You can then edit the steps of the automation as needed.
Can I duplicate an automation rule?
Yes!
In the automations side panel that lists all the automations within your doc, right-click the name of the automation rule you’d like to duplicate.
Select Duplicate
The newly created rule will open for you automatically.
How do I delete my automation rule?
In the automation side panel that lists all the automations within your doc, right-click the name of the automation rule you’d like to delete.
Select Delete
Can I see whether a specific table is referenced by an automation?
Yes, you can use the doc map to see whether a table is referenced by any automations. Check out this article to learn how.
