Keyboard shortcuts in Superhuman Docs
Learn how to use keyboard shortcuts in Superhuman Docs to more efficiently navigate your documents, format text, and manage your workspace.
Keyboard shortcuts are a great way to save time and work faster in Superhuman Docs. Many of the standard keyboard shortcuts work seamlessly in Docs, and we also have some Docs-specific shortcuts available.
This article contains the full list of keyboard shortcuts for both Mac and PC. You can also pull up this list in the product by simply typing Ctrl + / on a Mac, or Ctrl + Shift + / on a PC.
Mac shortcuts
General
  • Cut: ⌘ + X
  • Copy: ⌘ + C
  • Paste ⌘ + V
  • Undo: ⌘ + Z
  • Redo: ⌘ + Shift + Z
  • Search: ⌘ + Shift + F
  • Previous page: ⌘ + Option + [
  • Next page: ⌘ + Option + ]
  • Open explore planel: ⌘ + /
  • Toggle page list: ⌘ + \
  • Show word count: ⌘ + Shift + C
  • Present doc: ⌘ + Shift + P
  • Expand and show pages list: ⌘ + \
  • Navigate subpages in header: arrow keys
  • Go to highlighted page link: Enter
  • Move from subpage to parent page: Shift + Esc
  • Collapse all content: Cmd + . to expand or collapse the current section, and use Cmd + Opt + . to expand or collapse all sections.
  • Copy link to current block: ⌘ + Ctrl + L
Text
  • Bold: ⌘ + B
  • Italic: ⌘ + I
  • Underline: ⌘ + U
  • Strikethrough: ⌘ + Shift + K
  • Inline Code: ` (with selected text)
  • Expand Cell: ⌘ + Shift + E
Paragraph
  • Normal: ⌘ + Option + 0
  • Large header: ⌘ + Option + 1
  • Medium header: ⌘ + Option + 2
  • Small header: ⌘ + Option + 3
  • X-small header: ⌘ + Option + 4
  • Numbered list: ⌘ + Shift + 7
  • Bulleted list: ⌘ + Shift + 8
  • Checklist: ⌘ + Shift + 9
  • Collapsible list: ⌘ + Shift + 0
  • Block quote: ⌘ + Shift + .
  • Pull quote: ⌘ + Shift + '
  • Code block: ⌘ + Shift + ,
  • Indent/Outdent: Ctrl + ] or [
  • Move a paragraph: Option + ⬆ or ⬇
  • Check a list item: ⌘ + Enter
Insert
  • Reference: @
  • Formula: =
  • Hyperlink: ⌘ + K
  • Emoji: :emoji name:
  • Comment: ⌘ + Shift + M
  • Today's date: ⌘ + Shift + D
Tables
  • Open a row: Option + Space
  • Select a row: Shift + Space
  • Select multiple rows: Shift + ⬆ or ⬇
  • Move a row: Option + ⬆ or ⬇
  • Move a column: Option + ← or →
  • Insert a row: Enter (from last row in table)
  • Insert a column: Tab (when last column is selected)
  • Move to end of row or column: ⌘ + ⬆, ⬇, ← or →
  • Edit a cell: Space or F2
PC shortcuts
General
  • Cut: Ctrl + X
  • Copy: Ctrl + C
  • Paste Ctrl + V
  • Undo: Ctrl + Z
  • Redo: Ctrl + Y
  • Search: Ctrl + Shift + F
  • Previous page: Ctrl + Alt + up arrow
  • Next page: Ctrl + Alt + down arrow
  • Open Explore Panel: Ctrl + /
  • Toggle page list: Ctrl + \
  • Show word count: Ctrl + Shift + C
  • Present doc: Ctrl + Shift + P
  • Expand and show pages list: Ctrl + \
  • Collapse all content: Ctrl + . to expand or collapse the current section, and use Ctrl + Alt + Shift + . to expand or collapse all sections.
  • Copy link to current block: Ctrl + Alt + L
Text
  • Bold: Ctrl + B
  • Italic: Ctrl + I
  • Underline: Ctrl + U
  • Strikethrough: Ctrl + Shift + K
  • Expand Cell: Ctrl + Shift + E
Paragraph
  • Large header: Ctrl + Shift + 1
  • Medium header: Ctrl + Shift + 2
  • Small header: Ctrl + Shift + 3
  • X-small header: Ctrl + Shift + 4
  • Numbered list: Ctrl + Shift + 7
  • Bulleted list: Ctrl + Shift + 8
  • Checklist: Ctrl + Shift + 9
  • Collapsible list: Ctrl + Shift + 6
  • Block quote: Ctrl + Shift + .
  • Pull quote: Ctrl + Shift + '
  • Code block: Ctrl + Shift + ,
  • Move a paragraph: Alt + ⬆ or ⬇
  • Check a list item: Ctrl + Enter
Insert
  • Reference: @
  • Formula: =
  • Hyperlink: Ctrl + K
  • Comment: Ctrl + Shift + M
  • Today's date: Ctrl + Shift + D
Tables
  • Open a row: Alt + Space
  • Move a row: Alt + ⬆ or ⬇
  • Move a column: Alt + ← or →
  • Move to end of row or column: Ctrl + ⬆, ⬇, ← or →
Does Superhuman Docs support the use of Markdown?
Superhuman Docs does support some Markdown shortcuts. You can read more about it here.
How can I see a full list of these shortcuts from within my doc?
You can open an up-to-date list of keyboard shortcuts directly within your doc, with only a few keystrokes.
On a Mac, just type: Ctrl + /
On a PC, just type: Ctrl + Shift + /
