Superhuman Docs automatically makes your doc look great on a mobile device - here's how to get a sneak peek.
When you open a doc on your mobile device, Superhuman Docs will automatically make sure it looks great by optimizing it for your device. If you're building a doc that you plan to use mostly on mobile and want to check your work, it's easy. Here are the steps:
On a Mac
  1. In the Chrome View menu, choose View , Developer and Developer Tools
  2. Click the Mobile icon in the toolbar
    An image of the developer tools menu in Chrome.
  3. Select the type of device you want to use from the dropdown menu:
    An image of a dropdown to select a device type.
  4. Refresh your browser to see the mobile view
On a PC
  1. Click the ... menu in the upper right of your Chrome Window
    An image of browser settings on a PC, with developer tools highlighted.
  2. Choose Developer Tools
  3. Click the Mobile icon in the toolbar
    An image of the developer tools menu.
  4. Select the type of device you want to use from the device dropdown menu
  5. Refresh your browser to see the Docs mobile view
Pro Tip: Open your doc in an incognito window so you can see your doc progress on mobile as you build it.
