Learn which browsers and browser versions Coda supports, to ensure the smoothest experience.
To ensure the ideal experience while using Coda on desktop, we recommend using one of our supported browsers types. Coda supports the following browsers:
💡 For the smoothest, most secure experience, please ensure you're using the latest browser version. You can follow the links above to download the latest.
Mobile
While Coda works in most mobile browsers, we recommend using Coda's iOS and Android apps.
