Learn how to enable line numbers for the pages of your Superhuman doc.
Line numbers - or block numbers - allow you to identify specific sequences of text or other objects on the page of a Superhuman doc. When line numbers are shown, you can more easily reference exact places on a page, thus keeping your team and collaborators aligned.
While Superhuman Docs defaults to hiding line numbers, you can quickly change this setting to show the line numbers on specific pages, or on all pages in your doc. Once line numbers are turned on, you will see a number for each distinct block or each new line break on the page.
Show line numbers on a single page
To turn on line numbers for a specific page in your doc, just follow these steps:
  1. Navigate to the specific page in your doc
  2. Hover over the top of the page, and select Page options (above the page title)
  3. Choose See all options from the menu
  4. In the right panel, find and toggle on Line numbers
A gif demonstrating how to toggle on line numbers from the doc's page options settings panel.
That's it! You will now see line numbers appear on that specific page. These line numbers will be visible to everyone who views the page - not just to you. To turn on line numbers for all other pages, check out the next section.
Turn on line numbers for all pages
To turn on line numbers for all pages in a doc, follow the steps below:
  1. Click on the three-dot menu in the upper-right corner of the doc
  2. Select Doc settings from the bottom of the menu
  3. Select Page default
  4. Find Line numbers in the list of options:
    1. To turn on line numbers for all future pages in this doc, switch on the toggle.
    2. To turn on line numbers for all existing pages, click the page icon next to the toggle. You will then see a confirmation dialog. Click Apply to confirm.
A gif demonstrating a user toggling on
Page numbers will now be visible to all doc viewers on all pages of the doc.
What qualifies as a new line on a page?
In Superhuman Docs, a new line starts every time there is a line break. For instance, if you press Enter on your keyboard, this will create a new line break (and the next line number). But if you press Shift+Enter, this is not considered a new line break (and therefore will not start a new line number).
Is there a way to turn on line numbers for all docs at once?
At this time, there isn't any way to turn on line numbers for all docs at once. You will have to turn on line numbers for docs one by one.
Can I copy and share links to specific line numbers?
Yes - you can easily copy the link to a specific line number, then share this link with others. When they click the link, they will be brought to that specific line number on the page.
To copy a line number, just hover next to the number on the page, click the three vertical dots that appear, and select Copy link.
A gif demonstrating a user copying a link to a specific line.
