Learn how to authenticate a Pack and connect it to your account.
Not all Packs require authentication, but those that are accessing private data in another application or service will first need to be connected to your account.
What are Pack accounts?
A Pack account represents your account in another app or service that the Pack will connect to. For example, the Slack Pack needs to connect to your Slack account. You can add multiple accounts for the same Pack, for instance if you are a part of multiple Slack workspaces.
Connect an account
- Click Insert in the upper right of your doc
- Select Packs.
- Select one of your installed Packs, or search for the Pack you’d like to add to the doc if it’s not already installed.
- Click Settings. You’ll see options to connect an account under Select account for taking private actions and Manage synced accounts.
- An account for taking private actions is one that only you—the person who set it up— can use to take actions in the Coda doc.
- A synced account is one that, by default, can be used to sync data into the Coda doc. Anyone who has access to the doc will be able to view data that’s synced in (e.g. if you add a sync table of Google calendar events, everyone on the doc will be able to view the data on that table).
ℹ️ Sync tables always require a synced account. You cannot set up a sync table using an account for private actions.
To add another account for taking private actions, click on the dropdown and select + Add a new account.
Manage synced account permissions
Sync in data using this account: Doc editors can use this account to sync data into the doc themselves. Everyone in the doc will be able to view data that’s synced in.
- Note: this permission must be granted if you want to sync data into a Pack column or formula.
Take actions using this account: Doc editors can use this account to take actions through Pack buttons and automations.
- Note: this permission cannot be granted unless doc editors are also allowed to sync in data using the account
Disconnect an account
If you want to disconnect a shared account so that other folks in your doc will no longer have access, you can do that via the Pack settings.
Click on Insert in the upper right corner of your doc
Click on Packs
Select the Pack in question
Under the Settings tab, find the shared account you want to disconnect
Click on the three-dot menu to the right of that account, and select Disconnect. When you see the confirmation prompt, hit Disconnect again.
If instead you want to fully disconnect an account from Coda, so that Coda no longer has access to this account, you can do this via your Coda account settings.
Head to your account page, and find the Accounts connected to Packs section
Scroll to the Pack in question
Find the account you’d like to disconnect, and click the down arrow to the left of it
You can then choose to either Disconnect this account from specific docs, or you can click Remove this account to remove all access to this account
How can I see which accounts are connected for a given Pack?
The easiest way to find this information is to click on Insert in the upper right corner of your doc, then Packs, then the Pack name, then click into the Settings tab. Here, you’ll see a list of all the accounts connected for this Pack.
How can view all of my accounts, for all Packs?
Open your account settings and scroll down to the ACCOUNTS CONNECTED TO PACKS section. There you can find a list of all of the Packs you’ve authenticated with, which accounts you have connected them to, and which docs are using those accounts. From there you can disconnect an account from a particular doc, or remove it entirely from your Coda account.
How does Coda keep my account data secure?
Security is top-of-mind when it comes to Packs. You can read all about how Coda keeps your account data secure here.
