Learn the basics of Superhuman Docs notifications, including in-doc vs. email notifications. Adjust your email preferences and unsubscribe if needed.
Notifications in Superhuman Docs help you and your team stay in sync. These notifications - which can take the form of in-doc notifications, emails, or both - ensure that nothing slips through the cracks. They help you know just where your teammates need you.
This article will cover the basics of Docs notifications, including what triggers notifications, how to access your notification center, how to customize notifications preferences, how to unsubscribe from certain email notifications, and more.
Notification formats
Notifications from Docs come in two forms:
  1. In-doc notifications: These can be found in the notification hub, in the upper-left corner of your doc (by clicking on the bell icon 🔔). All notifications can be found here. Learn more in the section below.
  2. Emails: Docs will also send email notifications to the email address associated with your Docs account. You can choose to opt out of these notifications by following the steps in the section below.
ℹ️ If you’ve set up Superhuman Docs for Slack, you can also receive notifications via Slack messages. When you @-mention someone in a comment or a doc, Superhuman Docs for Slack will alert the @-mentioned user(s) so they can quickly find their mention and respond or take action. Added bonus: the app aggregates these for each user in Slack, so you don’t have to search through all of the comments in a doc to find where you’re mentioned! Learn more here.
In-doc notifications live in your notification center. This can be found while in any doc, by clicking on the bell icon 🔔 in the upper-left corner of the doc.
Whenever you have unread notifications, you’ll see a badge next to this bell, indicating that you have unread notifications.
When you open your notification center, you’ll see a feed of in-doc notifications, starting with the most recent. You can use the toggle at the top of the list to choose between All (all notifications across all docs), and This doc (only notifications pertaining to the current doc).
Clicking on a notification will take you to the location where that notification was triggered. So for instance, if the notification was caused by a comment on a row, you’ll be taken to that specific row in the doc. If the notification stems from another doc, a new tab will open and lead you to that location. If the notification stems from the current doc, you will simply jump to that location while remaining in the same tab.
Email notifications
By default, Docs will send you an email when someone mentions you in a comment or references your name in a doc that is shared with you. That way, you'll know if something needs your attention.
Check out the section below to learn how to adjust your email notification preferences, including how to opt out of these email notifications.
Notification triggers
There are a variety of things that trigger notifications in Docs. Some of the most common triggers are described in the table below:
Trigger
Example
Tagging (or @-mentioning) Someone tags you anywhere in a doc (via @ mentioning), such as the canvas, a canvas column, a comment thread, etc.
People columns Someone adds you to a People column (assuming they’ve also shared the doc with you and turned on notifications for the column; learn more here)
Comments Someone comments on a row, table, page, or doc that you’ve subscribed to (learn more here)
Doc access requests Someone requests access to a doc you own
Notify buttons Buttons can be set up to send custom notifications to a user (or users) whenever clicked.
Notify automations You set up an automation that sends a custom notification to yourself, so you are notified whenever that automation runs.
Additionally, there are some less common notification triggers that you might encounter. For instance, you’ll get notified when your doc exceeds its size or automation limits, when someone shares a doc with you, when someone transfers doc ownership to you, and more.
Adjust email notification preferences
You can adjust your email notification preferences in your account settings. Just follow these steps:
  1. Click on your avatar in the lower-left corner of a doc, and select Account settings
    1. Alternatively, go to superhuman.docs.com/account
  2. Scroll down to the Email settings section
  3. Under the Strictly business category, you can toggle on or off as needed. If you don’t want to receive email notifications for in-doc mentions or comments, toggle off the first option.
That’s it. The changes will take effect going forward.
How do I unsubscribe from emails from Superhuman Docs?
You can unsubscribe from emails and email notifications in your Superhuman Docs account settings. Just scroll to the Email settings sections, where you can opt out of various types of emails, including comment notifications, newsletters, and more. Learn more in the section above.
Why am I not receiving email notifications from Superhuman Docs?
This may be due to these email notifications being disabled in your account settings. You can check to see whether you’ve disabled email notifications by following the steps in the Adjust email notification preferences section above.
Can I turn off or customize in-doc notifications?
It’s not currently possible to fully disable in-doc notifications. But you can choose to opt out of notifications from comments on a page and doc level. Learn more about this here.
How does the “notify when added” setting within the People columns work?
If someone has access to the doc already, then they will automatically receive a notification whenever you add them to a People column (assuming this notification setting is toggled on).
Note: Even with this setting toggled on, notifications will only be sent to people if they already have access to the doc.
If I add someone to a People column in a doc they don’t have access to, will they be notified?
No. If the doc is not shared with them, you can add them to a People column and they will not be notified (even if notifications for that column are turned on). They will only receive notifications if you share the doc with them and have notifications turned on for the column. Learn more about People columns and their settings here.
