Import Trello data into Docs
Learn how you can easily import Trello Board data into Superhuman Docs using our importer tool.
One of the easiest ways to get started in Superhuman Docs is with existing data from another app. Importing a Trello Board into Docs is simple using our Trello Import wizard. To explore other import options, check out this article.
Before you get started
Before you initiate your Trello import, check out these key concepts to understand how your data will transfer over to Docs.
A Trello Board consists of:
  • Cards that are organized into Lists
  • Each card can be assigned to one or more Assignees (people you are collaborating with)
  • Cards can be tagged with Labels
  • Cards can also have Checklist items.
When importing your Cards into Docs, we'll create a new page for you based on the name of the board you're importing from. The data for each board will be stored in a single table with a row for each card. This table has columns for things like title, description, and assignees.
When you import you can optionally include checklist items. If you do, we'll create a second table for the items linked with a relation column to the owning card.
Initiate your Trello import
To import from Trello, type /import into the canvas, and select the Trello option.
Click Next and you'll be prompted for permission to allow us to access your Trello data. This may look a bit daunting, but good news: you're allowing us to read your data for only an hour. Once you click Allow you can then pick the board you want to import and optionally include the checklist items.
Voila! You're done.
