Move your projects and tasks from Asana into Superhuman Docs in just a few clicks.
With our Asana importer, you can easily transfer your Asana data into your Superhuman docs in just a few clicks. To start the process, simply export your Asana project as a CSV, then upload the CSV file to Docs via our Asana importer. Continue reading to learn all about this process.
Export your data from Asana
To get started, you will first need to export your data from Asana in the form of a CSV. Follow the steps below to complete this:
ℹ️ Note that you can only export one project at a time, each as a separate CSV file. If you need to import larger amounts of data, please contact Support for assistance.
  1. Within Asana, select the project you wish to export
  2. At the top of the project page, select the chevron icon to the right of the project name
  3. From the list of options, hover over Export or sync, then select Project tasks CSV/XLSX
  4. In the pop-up window, ensure that CSV is selected as the format. We also suggest selecting All custom fields including multi-homed tasks
  5. Then select Export to confirm
  6. Repeat the above process with any other projects you wish to export
Now that you’ve downloaded the necessary CSV files from Asana, the next step is to import these files into Coda. Continue to the next section to learn how.
Import files into Docs
With the CSV files exported from Asana, you can now import those files into your doc.
  1. Open the desired doc in Superhuman
  2. Type /Asana on any blank line on your page
  3. Select the Asana option (under the Import heading)
    1. Note: Do not select the Asana option under the Packs heading.
  4. Click Next to continue
  5. Click into the File field, and select the recently downloaded CSV from your files
  6. Use the Import location field to choose whether you want your project imported as a new table or added to an existing table
  7. We recommend leaving the Use first row as headers option toggled on
  8. Finally, click Next to initiate the import
You’ll now see your Asana project data imported as a Coda table. To learn all about using and customizing tables, start here.
Can I export and import an entire Asana workspace at once?
At this time, you can only export one project at a time from Asana. Therefore, you will need to export each Asana project individually. You can then upload multiple CSV files at once via the importer in Coda.
If it is not feasible to export each project individually due to the quantity of data in Asana, our team may be able to help. Please contact Coda Support to learn more.
Can I sync my data between Asana and Superhuman Docs, rather than importing it?
Yes, if you wish to simply view a version of your Asana data in Docs, you can use the Asana Pack. This Pack allows you to pull your Asana projects into your docs for easy viewing. Learn more here.
