Forgot your Coda login details or lost access to your 2FA? Here's how to regain access.
It happens to all of us. This article will cover how to reset your Coda login password, including what to do if you've lost access to your multi-factor authentication device.
Reset your password
The method for resetting your password varies depending on what login method you use. To see a list of available sign-in methods, check out this article.
Email & password logins
If you use the standard email and password login to access Coda, just follow these steps to reset your password:
  1. Go to https://coda.io/signin
  2. Click on the sign in with a password option
  3. Click the Forgot password? option
  4. Enter your email address, then click Reset password
  5. Check your email for a password reset email from Coda, and follow the prompts there to complete the process of resetting your password.
Google logins
If you signed up to Coda with Google, you will not be able to reset your password using the Forgot password? link. Instead, follow Google’s Account recovery steps to regain access to your Google login, then sign in with Coda.
If you need to deactivate your Google account, make sure you first go to your Coda account settings and switch to an email and password login. To do so, look for the Security settings section, find the Password option, and click Add to add a password. Once this is set up, you can then deactivate your Google account.
If you’ve lost access to your Google account and need to to recover your associated Coda account, please contact Coda Support. You can do so by clicking the question mark icon in the lower right corner of any doc, then choosing Contact support.
Lost two-factor authentication device
Life happens. If you've lost access to your two-factor (2FA) or multi-factor (MFA) authentication method, we can manually reset your account. This reset process requires a mandatory 14-day waiting period during which you can contact us to cancel the request. To start this process, please reach out to Coda Support. You can do so by clicking the question mark icon in the lower right corner of any doc, then choosing Contact support. Alternatively, if you're logged out of Coda, just shoot us an email at support@coda.io.
Learn more about 2FA and the process of resetting your 2FA here.
