Learn how to connect and use the Lever Pack within your docs.
You can use the Lever Pack to pull info about candidates, candidate stages, and postings directly into your Superhuman doc. This allows you to have your data in the same place where your work actually gets done. Continue reading to learn how to install, connect to, and start using the Lever Pack.
ℹ️ The Lever Pack is only available to customers on our Team and Enterprise plans. If you're on a Free or Pro plan and would like access to the Pack, consider upgrading your workspace.
Add the Lever Pack to your doc
To use the Lever Pack, you’ll first have to add it to your doc. Just follow the steps below to do so:
  1. Click Insert in the upper right of your doc
  2. Type "Lever" in the search bar
  3. Choose Lever from the options
  4. A window will open with some info about the Lever Pack. Click Add to doc to finish.
The Pack has now been added to your doc. To explore and start using the Pack, check out the following section.
Put the Lever Pack to use
Now that you’ve added the Lever Pack to your doc, you can browse the available building blocks by following these steps:
  2. Select Packs
  3. Under Installed Packs, select Lever
  4. Scroll through the Building blocks tab to see all the ways you can start using the Pack.
💡 Want even more info about the Lever Pack, its building blocks, and the security of the Pack? Check out the Pack listing page.
To add a building block - such as a Candidates table or a Posting column - simply drag it from the panel on the right and drop it into the correct spot on your page.
You will then be prompted to connect to your Lever account in order to access that Lever data. Click on Connect an account and follow the steps. If this is your first time connecting to the Lever Pack, you’ll be prompted to sign in to your Lever account.
ℹ️ If you need a refresher or have any questions on connecting to Pack accounts, check out this article.
What data is available in the Lever Pack?
Using the Level Pack, you can sync the following data into Superhuman Docs:
  • Sync tables:
    • Candidates
    • Postings
    • Candidate stages
  • Columns:
    • Candidates
    • Postings
The Pack also gives you access to the following Pack-specific formulas:
  • Candidate()
  • Posting()
Check out the Pack listing page for more details.
How much does the Lever Pack cost?
The Lever Pack is included at no extra charge to all customers on our Team or Enterprise plans. Customers on the Docs Pro plan have the option to purchase the Pack for an additional charge. The Pack is not available to customers on the Free plan.
Should I use a shared or private account when connecting to the Lever Pack?
The answer depends on your preferences and how you intend to use the table or column. Check out this article to learn about the difference between shared and private accounts.
