Generate browser console logs for troubleshooting
Learn how to view, save, and share your browser console logs with support when troubleshooting in Superhuman Docs.
In some unique circumstances, the Superhuman Docs support team may request that you share the content of your browser's console logs to help us troubleshoot a problem. The steps in this article will explain how to access and share those console logs with the Docs team.
📣 Depending on the nature of the issue, the Docs support team may alternatively ask you to generate a HAR file (e.g., for slow loading) or a performance profile (e.g., taking too long to add a row) for troubleshooting. Follow the respective hyperlinks to learn more about generating those files.
Retrieve console logs from Chrome
Follow the steps below to retrieve the browser console logs from Chrome:
  1. Open the main Chrome menu using the three dots in the top right of your browser
  2. Hover over the More Tools option, then select Developer Tools
  3. Click into the Console tab
  4. While keeping the console open, reproduce the issue you’re experiencing in Docs
  5. Then right-click on the text logs within the console tab, select Save as, and choose where to save this file
  6. Finally, share this downloaded file with Docs support.
Retrieve console logs from Firefox
To generate and share the console logs from a Firefox browser, follow these steps:
  1. Open the Firefox Tools menu by clicking the three lines in the upper right corner of your browser
  2. Select More tools, then select Web Developer Tools
  3. Click into the Console tab of the web developer tools
  4. With the console still open, reproduce the issue you’re having in Docs
  5. Right-click on the logs in the Console tab, select Save all Messages to File, then choose a destination for this file
  6. Finally, share the recently downloaded file with Docs support
Retrieve console logs from Safari
If you’re using Safari as your browser, follow the steps below to retrieve and share console logs:
  1. In the menu bar, click on Safari then select Settings
  2. Click into the Advanced tab of the settings, and make sure the Show features for web developers box is checked.
  3. Then close the settings and return to your Safari browser.
  4. Now click on Develop in the menu bar, and select Show JavaScript Console. This should take you to the Console tab.
  5. Reproduce the Docs issue you’ve been experiencing in your browser
  6. Within the Console tab, use the Cmd+a shortcut (Mac) or Ctrl+a shortcut (PC) to highlight the full console log. Then right-click, select Save selected, and choose a destination for this file.
  7. Finally, share this file directly with Docs support.
ℹ️ Please note that the UX for these third-party tools might differ slightly from what is described below. To resolve any confusion and access the most up-to-date info, we recommend referring to the official help center for your browser type.
