Get started quickly in Superhuman Docs using these quick-start shortcuts.
If you're new to Superhuman Docs, you might not know exactly what you'd like to build yet. Not to worry! Here's where drag-and-drop templates come in. They'll help you get started quickly, and give your doc a supercharge. Let's take a look.
You can add drag-and-drop templates either from the Explore panel in your doc's header, or by using the slash command to enter them directly in the canvas. Let's explore each:
Using the slash command
To insert a template using the slash command, type the / on a new line on your canvas. This will pull up a dropdown menu that gives you the option to insert different building blocks into your docs.
You can search by name for the template you want to use, or scroll through popular options. Once you find the template you want, you can highlight it and click on it, or hit the return key to add it to the canvas.
Using the Insert panel
If you prefer to browse different drag-and-drop templates, you might prefer to use the Insert panel to add templates instead. To do that, click the Insert & explore button in the upper-right corner of the page.
From there, you'll be able to select the templates option to open a menu of templates. You can choose from popular existing templates or browse by collection.
Once you find the template you want to add, drag and drop it onto your canvas and the template will be inserted.
Don't forget that you can search for any template by name in the explore panel!
📣 Want to create your own custom templates for yourself and your teammates? Check out this article to learn how.
