Overview: Import data into Superhuman Docs
Want to bring data into Docs but unsure what import option is best for you? Explore the various options in this article.
Whether you’re new to Superhuman Docs or a seasoned pro, you may want to pull data from other sources into your doc. Good news - we have lots of options to help facilitate this. You can even find app-specific importer tools that make transitioning off your existing tools a breeze.
To explore importing options within your doc, just type /import into the canvas. Or click on the Insert & explore button in the upper-right corner of your doc, then select Import.
Import directly from another app
With our native importers, Superhuman Docs makes it easy to pull your projects from another app into Docs - all while preserving formatting and connections.
Check out any of the below articles to learn more.
Import spreadsheets
Bringing data from a spreadsheet? Superhuman Docs supports importing both XLSX and CSV files, so you can bring your data - and with Excel or Sheets, your formulas - straight into a working table.
Import text files
Want to import content from a document or wiki? Superhuman Docs supports pasting text from a wide range of documents and will preserve the core formatting of the content. Read more about this at the links below.
Import a table manually
If you're starting from data in a spreadsheet, and you aren’t able to use one of our other importing features, you can always copy and paste. Refer to the article below for some details on how to do this:
Import from 3rd-party applications with Packs
Packs allow you to connect to applications you and your team use every day like Gmail, Google Calendar, Slack, Intercom, and more. Click on the Insert & explore button in the upper right of your doc, then select Packs. Or to learn more about Packs, check out the article below:
Set up an ongoing import with Zapier
If you need to import data on a continual basis (e.g. customer feedback, deal status, JIRA issues, etc.), you can use Zapier to build a connection:
