Learn how to easily import Notion data into Coda. Bring your Notion workspace to life with Coda's building blocks, Packs, and automations.
So you want to move some - or all - of your data from Notion to Coda. Luckily, we’ve built some powerful importers that allow you to do just that. With a few clicks, you can now import your Notion pages or workspace to Coda. Read on for more details, or watch this video walkthrough:
Export from Notion
To kick off the process of bringing your Notion data into Coda, you’ll first want to export from Notion. You can follow the steps outlined under the “Export as HTML” section of this article.
When exporting, Notion will give you a few options. We recommend the following:
Toggle on the "Include subpages" option. Since all tables in Notion rely on data from subpages, exporting without these will prevent your tables from importing to Coda.
Toggle on the "Create folders for subpages" option, especially if your workspace contains database pages. This will ensure that those database pages are imported as canvas columns rather than as subpages.
Once you have your export, you can import the file into Coda as a new doc, or to an existing doc.
ℹ️ Please note: If your zipped Notion export file is over 2GB, you will need to first unzip the file before you can upload it to Coda.
Import to Coda as a new doc
💡 Tip: To preserve people references (i.e. @Jonny Appleseed in your export), start with a blank doc and share it with those referenced in your Notion doc before importing.
To create a brand new Coda doc with your Notion export, just follow these steps:
Navigate to your doc list at coda.io/docs
Click the Use template button
Select the Import option from the bottom-left of the menu
Find and click on the Notion option
In the new doc, click the Continue to upload button
Then click the Upload ZIP file button
Choose your zipped file, and click Open
Note: If your file is greater than 2GB, you will need to first unzip it and then upload the unzipped folder to Coda.
Be aware that large files may take a while to fully import. See our FAQ on load time below for more info.
Import to an existing Coda doc
If you want to add your Notion data to an existing Coda doc, follow these easy steps:
Open the desired Coda doc
Type /notion anywhere on your page
Alternatively, just click on the Insert tab in the upper right of your doc, then click into Import
Select the Notion option (under the Import heading)
Click Continue to upload
After importing
Once your import is complete, there may be a few finishing touches that are needed to ensure a smooth migration to Coda. You should see a new page in your doc, titled Read me: Import next steps. This page is automatically added to help you with any next steps or fixes to your import.
To learn more, select the Import fixes subpage, since this is where we note some limitations of what can be imported from Notion. In the table, you will find a complete list of all the issues in your recent import, along with a suggested solution and a link to the location of the issue. We've even included columns to help you assign issues to someone and track the resolution of these issues.
Once all issues have been successfully resolved, or you're satisfied with what you've resolved so far, you can simply delete the Read me: Import next steps page and its subpages. Alternatively, you can hide the pages to save for future reference.
📣 Looking for more info on migrating your workspace or company from Notion to Coda? Check out this comprehensive guide.
Why should I switch from Notion to Coda?
Great question! We've put together this comprehensive resource to help you evaluate a possible switch from Notion to Coda - check it out.
I'm seeing a "Something's not right" error when trying to import my Notion workspace. How can I resolve this?
This error can be caused by a number of different issues. You may sometimes encounter this error if your workspace is particularly large. Therefore, you can try to work around it by importing smaller portions (such as single pages) at a time, rather than the entire workspace at once.
What will happen to formulas, filtering, and views when I move data from Notion to Coda?
HTML exports do not support formulas, filtering, and alternative database views, so they won’t come through “as is” in your imports to Coda. However, Coda will retain the values and data, allowing you to apply new formulas or filters after importing. After the import is complete, you can refer to the Read me: Import next steps pages in your doc to learn more about what updates are needed.
At the moment, the HTML export is the best option for import fidelity. We are working on updates to the Importer to leverage the Notion API.
What will happen to date formatting when I move data from Notion to Coda?
In the HTML export, there is no information about the specific date format used - only plain text, which could be ambiguous while parsing. To avoid potential misconversion, all dates are aligned with the document settings where the import is performed. We recommmend double-checking your imported dates to make sure they're formatted as desired, and make updates as needed.
What will happen to select, multi-select, and status columns in a database when I move data from Notion to Coda?
In the HTML export, only the options that are actually used in select, multi-select, or status columns are included. Any unused options are omitted. To restore the complete list of options for these columns, you will need to manually add any missing values.
What will happen to cell colors in a database when I move data from Notion to Coda?
The Notion export does not provide information about cell background colors in databases. As a result, these colors cannot be imported and will need to be manually applied if necessary.
Does “workspace” mean something different in Notion than in Coda?
Yes. The term “workspace” means different things between Notion & Coda. In Coda, your workspace is the home base for your team, with folders to organize your docs and permissions. Within your folders, you have docs.
What Notion calls a “workspace” will feel much like a single Coda doc, with subpages. But, in Coda, you can have as many docs you want within the same folder or workspace vs. a single “workspace” in Notion. If you wish to retain each Notion page as a distinct entity, export each page individually to convert each into a doc with its own permissions.
I’m on Safari and running into issues with my Notion import. What can I do?
If you use Safari, update your General Settings so that the Open “safe” files after downloading option is unchecked before you get started. Otherwise, Safari will automatically unzip your Notion export, which will hinder you from importing to Coda.
Why is my Notion import taking so long to complete?
Large imports may take up to a few hours to complete (e.g. 2 GB+). Minimize your browser window and let the importer run in the background while Coda does all of the work for you! Give your import ample time to load.
Closing the window restarts the upload of your Notion doc(s) to our servers. If you see an error message when you try to close the window or navigate to another page, that means the import is not done loading yet. If you do leave the window, the import will typically resume or restart the next time you visit the page.
How can I learn more about migrating from Notion to Coda?
While this article covers instructions on importing data from Notion to Coda, we recommend checking out this comprehensive guide for more details on the process of migrating from Notion to Coda.
Is there a file size limit when importing from Notion?
For best results, we recommend keeping the zip file under 500 MB.
Currently, Coda cannot import zip files larger than 2GB. If your zip file is above this size limit, please first unzip the file, then upload the unzipped folder to Coda.
What is causing Notion import failures on Windows?
Large Notion exports can sometimes fail to import into Coda when the import is run on a Windows machine. The issue is due to Windows’ Maximum Path Length limitation. By default, the maximum length for a file path is 260 characters (known as MAX_PATH). When importing files or folders with longer paths, they cannot be processed correctly, resulting in failures.
How can I enable support for longer file paths on Windows?
Do I need to restart my computer after enabling long paths?
What steps should I follow after enabling long paths?
- Download the Notion export file from your email.
- Unarchive (unzip) the file. Verify that the new folder is clearly named and does not conflict with any previous copies.
- Use the latest version of Microsoft Edge for importing, as it integrates best with Windows.
- Initiate the import in Coda, selecting the newly unarchived Notion space.
- If the import does not complete, retry using the latest version of Chrome.
What if I am using macOS?
If issues persist despite previous steps, try the following troubleshooting measures in order:
- Export your Notion workspace in smaller parts, such as by nested pages.
- Move the exported Notion folder to the root of C:\ to shorten the path.
- Try importing individual files separately.
